12-04-2012, 02:33 PM | #1 |
How low can I go?
Ok wondering how low I can go on my 87! prob going to do a compleat kit with a flip kit drop spenddls lowering springs and new shocks all the way around but how low can I go without having to notch my frame
Posted via Mobile Device |
12-04-2012, 03:02 PM | #2 |
At the body shop.
Re: How low can I go?
Usually a flip wont require a notch. Remove the bumpstop and bracket.
" That didnt make it any newer " " Dont antique the equipment " |
12-04-2012, 04:31 PM | #3 |
About 5in in the rear as long as the springs are not altered. For a level look, do a 3.5/5in kit or for a little rake you can do a 4.5/5in kit.
John 82 Chevy Silverado 350ci/TH350 |
12-04-2012, 04:47 PM | #4 |
I have a question since I am going to drop my truck I'm looking at a 4/6 drop will I still be able to have clearance with that or should I go more along with 3-3.5/5?
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
12-04-2012, 04:54 PM | #5 |
Ground clearance or axle to frame clearance?
12-04-2012, 05:07 PM | #6 |
ground
12-04-2012, 05:27 PM | #7 |
What tires are you running?
12-04-2012, 05:34 PM | #8 |
right now i'm running 235/75/15, but when I go drop it i'm going to run some 245/45/15
12-04-2012, 05:41 PM | #9 |
I think you meant245/60/15. Personally, i would do the 3.5/5
12-04-2012, 05:45 PM | #10 |
Okay thanks for the help. Its just hard to decide haha.
12-04-2012, 05:49 PM | #11 |
What I'm going to end up doing is just buy a 3-3.5/5 drop and if I like it I'll keep it, but if I want lower I'll go spend the extra to get the 4/6 drop.
12-04-2012, 06:03 PM | #12 |
the tires I'm running measure 27 in from ground to top of tire... the kits I'm looking at doesn't have a 5 in drop can I get away with a 4/6?
12-04-2012, 06:28 PM | #13 |
look into belltech there prices are a little high but everyone recommends them, and to do a 4/6 you'll have to c-notch the frame.
12-04-2012, 06:28 PM | #14 | |
Yes.
12-04-2012, 06:45 PM | #15 |
Ooo no I wouldn't go 3 inch springs the 4/6 kit I was looking at through bell tech the spindles were 2.5 which leaves the springs 1.5-2.5 cause it says it'll give you a 4-5 drop in the front
12-04-2012, 07:14 PM | #16 |
2.5' drop spindles, cut 1.5 coils, flip kit, drop shackles and remove the 2nd and 3rd smallest leafs. then you can be in the weeds
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
