Old 12-04-2012, 03:20 PM   #1
The German
The German's Avatar
Engine Nr...gm target master 10066036
Hi guys!
I have the engine no.10066036!
Now i want to order some parts at summit!
The question is...is it a small block generation I or Chevy small block Gen II (LT-based engines)!?
Regards
Sascha
The German is offline   Reply With Quote
Old 12-04-2012, 03:38 PM   #2
trac209
Re: Engine Nr...gm target master 10066036
The engine is a 1st gen small block. as long as the heads have not been changed to vortec or tbi heads. Are they perimeter bolt valve covers or center bolt? as long as they are perimeter style valve covers all early sbc parts will bolt onto it. The other heads on that block will require different intakes as they use specific bolt angles and configurations. hope this helps
trac209 is offline   Reply With Quote
Old 12-04-2012, 03:46 PM   #3
Lee H
Lee H's Avatar
A quick search on google was not much help, appears they could be either, although most discussion leaned towards gen 1. What is the date code, which side is the dip stick on? If it has heads on it what are they? Do you know if it's one or two piece rear main?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-05-2012, 03:53 PM   #4
The German
The German's Avatar
The date code is 93! The dipstick is und the passenger side! I have mounted edelbrock zylinderhead covers. This are stock covers from a small block!
Sascha
