Old 12-04-2012, 04:24 PM   #1
scum1
scum1's Avatar
Honing motorcycle cylinder ?
Hey guys im working on a 79 yamaha xs650 project, and i just did a valve job cuz of some bent valves, while the motor is apart i replaced the piston rings and cleaned up the piston. I did some measuring on the clearances with the new rings in the cylinder (on piston) and everything was to spec. My question is should i hone the cylinder before i reassemble? and if so should i use a ball hone or the stone spring hone..with the clearances to spec and new stock rings i dont want to risk the new rings not sealing properly..any thoughts??
scum1 is offline   Reply With Quote
