Old 12-04-2012, 06:32 PM   #1
afcamaro
afcamaro's Avatar
Tailgate Rod clips
I am having a hard time finding tailgate rod clips. The clips or locking nuts that go on the end of the rods and into the tailgate latch so they do not fall out of the latch itself. I cant find them in any magazine I have. Does anyone have a part number or something close that would work at the parts store even. They dont have to be original just fit. Thank you
afcamaro is offline   Reply With Quote
Old 12-04-2012, 06:37 PM   #2
Gokart Mozart
Re: Tailgate Rod clips
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=36 part 15?
Gokart Mozart is offline   Reply With Quote
Old 12-04-2012, 06:43 PM   #3
afcamaro
afcamaro's Avatar
Thanks for the reply but no, they go onto the inner rod and connect to the latch itself. (#5 in that diagram) I hope Im not dreaming these because wouldnt the rods fall out over time on the latch? I know i remember taking something off them to get the latch out.
Old 12-04-2012, 09:03 PM   #4
ole dollor
ole dollor's Avatar
i always found these clips very hard to find, i have threaded the end of the rod and put nuts on them to hold them on, and also drilled a hole in the rod and put a cotter pin with a washer to hold them on, worked good for me....maybe this will help...
ole dollor is offline   Reply With Quote
Old 12-04-2012, 09:32 PM   #5
pickupman
pickupman's Avatar
I call them barrell clips or bolts. a good hardware store should have them if not I have them available. can purchase them online at http://s-c-t-p.com/clipsfasteners.html , or you can email me at atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 12-04-2012, 09:45 PM   #6
vectorit
What?
vectorit's Avatar
Clips like that are best salvaged from original stuff.
The new clips I found are not strong enough, so they would just pop off after a few times using them.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-04-2012, 10:55 PM   #7
chiefcfd
chiefcfd's Avatar
My NAPA Store has them.
chiefcfd is offline   Reply With Quote
Old 12-05-2012, 08:12 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I recently went through this and just used some of the clips that hold inner door latch rods in place. (also used on other areas like throttle rods, choke rods, etc)
Was a bit challenging getting them in but now those rods stay put!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 12-05-2012, 01:28 PM   #9
CTENTA1
Registered 1971 K5
Would'nt that be #10 in the picture?
CTENTA1 is offline   Reply With Quote
Old 12-06-2012, 10:28 AM   #10
bodydropped68
bodydropped68's Avatar
Originally Posted by ctenta1 View Post
would'nt that be #10 in the picture?
x2
bodydropped68 is offline   Reply With Quote
Old 12-06-2012, 12:44 PM   #11
afcamaro
afcamaro's Avatar
Yes I beleive you guys are right. Guess I just didnt look at the picture clearly enough. I couldnt tell what that was off to the side but now it makes since. thanks
