Old 12-04-2012, 11:45 PM   #1
Metalshapes
Metalshapes's Avatar
swaybar
Hey fellas, I was wondering how big is the biggest sway bar that was offered for our trucks and what did it come on? 2 wheel drive.
Rally 'round the family....with a pocket full of shells.
Metalshapes is offline   Reply With Quote
Old 12-04-2012, 11:59 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: swaybar
1 1/4 off of like a one ton.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 12-05-2012, 12:04 AM   #3
cory d
cory d's Avatar
Re: swaybar
1 1/4. half tons have 1 1/16 or none at all. i put a 1 1/16 on mine but i have a 1 1/14 ready to go on, just need to order some bushings
cory d is offline   Reply With Quote
Old 12-05-2012, 01:21 AM   #4
lap15
Re: swaybar
I had a HD C20 with the 1 1/4 swaybar, so it was offered on 3/4 tons also.
lap15 is offline   Reply With Quote
Old 12-05-2012, 01:35 AM   #5
cory d
cory d's Avatar
Re: swaybar
it was offered on 3/4 tons too, my crew and the truck i got my 1 1/4 bar off o fwere 3/4 tons
Old 12-05-2012, 08:58 AM   #6
Rich84
Rich84's Avatar
Re: swaybar
Tell me..Is the sway bar worth getting? My truck doesn't have one.
Is it worth it to head to the boneyard and get one?
Rich84 is offline   Reply With Quote
Old 12-05-2012, 10:53 AM   #7
THE "10" SILVERADO
Re: swaybar
I have a 1 1/16th on my truck but I've heard a lot of good about them so I went ahead and got one off a 1 ton at the junkyard.
Michael
Old 12-05-2012, 12:13 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: swaybar
YES! If you have a 1 1/16 and step up to the larger bar you will notice a little difference. If you have no bar at all and add either one you will notice a LOT of difference.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-05-2012, 12:42 PM   #9
Metalshapes
Re: swaybar
Thanks guys I wasn't sure what the factory offered as I have aftermarket bars on my truck. Just was curious that's all, I like to learn.
Old 12-05-2012, 01:08 PM   #10
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: swaybar
If you don't have one then once you get one you will be amazed night and day difference on my truck then I stepped up to the one ton
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-05-2012, 01:15 PM   #11
Rich84
Rich84's Avatar
Re: swaybar
Does it handle different or ride different??
I noticed that it handles much better after just being lowered.
Old 12-05-2012, 01:17 PM   #12
cory d
cory d's Avatar
Re: swaybar
it will but the bar with help a bit more
Old 12-05-2012, 02:10 PM   #13
68Timber
I know the pieces fit
68Timber's Avatar
Re: swaybar
I saw the cheap digital dial calipers at Harbor Freight the other day ($8) and couldn't remember why I wanted one, now I do. I need it to get the right new bushings.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-05-2012, 02:13 PM   #14
cory d
cory d's Avatar
Re: swaybar
try wrenches, 1 1/16 is 27mm an 1 1/4 is 31.5
Old 12-05-2012, 06:32 PM   #15
tucsonjwt
Re: swaybar
My camper special 83 C20 has a stock front sway bar - I think it was standard on all camper specials, but I don't know the diameter. I got new bushings from the local parts shop (a Car Quest store, I think) and they were light blue in color. I sanded down the swaybar and painted it black when I had it out of the truck. x2 on night and day difference on handling and cornering - I mean, it is still a big 'ol truck and drives like one, but tighter steering and ride was not affected, except maybe a slightly better ride - less floaty on turns.
tucsonjwt is offline   Reply With Quote
Old 12-05-2012, 06:38 PM   #16
tucsonjwt
Re: swaybar
I got the same calipers a couple years ago. I probably use them twice a month or so - often to get the exact diameter for a nut or bolt. They seem to be accurate, until the battery starts to die. Just remember to close the jaws and push the zero button every time you use them. I seem to inadvertently touch the zero button when I am done using it and that resets the zero mark incorrectly.
Old 12-05-2012, 10:45 PM   #17
INSIDIOUS '86
Re: swaybar
Throw urethane in the middle and keep the outlets rubber. Get a rear cause the front will be stood enough that if you throw the wheel you will do a720* turn and lift the inside wheel almost haha.
Old 12-05-2012, 11:05 PM   #18
cory d
cory d's Avatar
Re: swaybar
im thinking about using all urethane and putting rubber pads with lock nuts under the outer bushing so it can pivit. that way it kills the rubber pad and not the bushings
Old 12-05-2012, 11:23 PM   #19
INSIDIOUS '86
Re: swaybar
Drill it and do away with that bushing style on the ends. Really no good
Old 12-05-2012, 11:35 PM   #20
INSIDIOUS '86
Re: swaybar
Old 12-06-2012, 08:08 AM   #21
68Timber
68Timber's Avatar
Re: swaybar
Cool, thanks, that's the type use I had it in mind for.
John
74 Honda Z50 build
Old 12-07-2012, 11:14 AM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
Re: swaybar
I'd heard bigger is better,gona hafta look for one...
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
