Old 12-04-2012, 11:49 PM   #1
combat72
combat72's Avatar
1970 Inner Grill Color Question
The inner grill on my 70 CST has been painted all silver by the previous owner. Would the correct color be all black except for the front edges of the egg crate? I know the vertical recess sections would be painted black. What would be the correct color of black?
Thanks,
Frank
combat72 is offline   Reply With Quote
Old 12-05-2012, 12:00 AM   #2
Mister-B
Re: 1970 Inner Grill Color Question
Thanks,
Frank
I've asked this before too, and it seems like the general consensus, is that they came stock sort of a dark greenish gray. At least on a 69, which is the closest you can get to a 70. They are plastic, and fade, so it's hard to really tell what they were like 40 years ago, and old photos probably won't be accurate either. I said screw it, and painted it black
Here's the before shot, and then the during and after shots
Mister-B is offline   Reply With Quote
Old 12-05-2012, 02:10 AM   #3
William72c20
I did the same on my 72 gave the truck a nice look
William72c20 is offline   Reply With Quote
Old 12-05-2012, 04:08 AM   #4
70cst
70cst's Avatar
I think the 69 & 70 inner Grilles were black. I'll let other chime in.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-05-2012, 08:01 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I recently asked about the 69 grill color and it seems it was not black but actually gray in color.
I'm still undecided what shade of gray I need for my 69 wrecker project. The original grill is good but appears to be weathered gray just like the first pic in Mister-B's post.
Would love to hear the exact shade if anyone knows.
Edit: just found an old pic of mine:
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 12-05-2012, 11:16 AM   #6
William72c20
I'm sure it was just a plastic grey . I painted mine black
1972 C20 402cid
Old 12-05-2012, 11:50 AM   #7
Longhorn 70
Longhorn 70's Avatar
I purchased this inner and outer grill from a local Chevy dealer in 1990. I am told it is the correct one for 1970.
Hope it helps.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-05-2012, 11:54 AM   #8
Mister-B
Hope it helps.
I believe they told you wrong about that inner piece with the crate pattern. In 70, they moved to the horizontal slats like you see in the green truck above. You've got a 69 grill and insert, but I believe your headlight trim should be black and not chrome.
Old 12-05-2012, 01:12 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by mister-b View Post
i believe they told you wrong about that inner piece with the crate pattern. In 70, they moved to the horizontal slats like you see in the green truck above. You've got a 69 grill and insert, but i believe your headlight trim should be black and not chrome.
posted via mobile device
x2.
Keith
Convert to disc brakes.
Old 12-05-2012, 04:19 PM   #10
Longhorn 70
I don't want to hijack the thread....but......DARN them!
Old 12-05-2012, 04:32 PM   #11
William72c20
Let's see some more blacked out inserts ??? New to the threads here
1972 C20 402cid
Old 12-05-2012, 07:49 PM   #12
combat72
combat72's Avatar
I appreciate all the replies. I looked through a bunch of threads trying to find a good picture. Found this one and was going off picture in 1st post
http://67-72chevytrucks.com/vboard/s....php?p=4501960
Also found this thread, lst picture in the 11th post
http://67-72chevytrucks.com/vboard/s....php?p=4450016
Looks to be all black expect for front edges of egg crate.
Frank
Old 12-05-2012, 08:27 PM   #13
Mister-B
I just realized something, based off Combat72's latest post. Check out this pic
According to that, the only thing that changed between 69 and 70, with the plastic grate behind, is how they painted it! If that's true, they DID sell you a 70 piece, but if you want it to look like a '70 piece, you would need to paint it differently
