Old 12-05-2012, 12:44 PM   #1
99-LS1-SS
99-LS1-SS's Avatar
Question about the gas tank
What holds the black plastic shield to the gas tank? I just go this truck and it has a new gas tank but the black plastic shield is zip tied on. I'm pretty sure it didn't come from the factory with zip ties... Can someone help me figure out how to fix this the right way?
Thanks.
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 12-05-2012, 01:53 PM   #2
64fleetside
Re: Question about the gas tank
Toss it, IMO. Their primary pupose is to hold mud/dirt up against the tank so it will rust out.
64fleetside is offline   Reply With Quote
Old 12-05-2012, 02:19 PM   #3
bohmankid
bohmankid's Avatar
I tossed mine as well. To me, the plastic does more harm then good. I took off the plastic covers and there was mud caked inbetween them and the gas tanks. The truck had not seen the mud in 6 months. Not to mention the mud was still wet! I was forced to replace the gas tank because it had rusted through.
bohmankid is offline   Reply With Quote
Old 12-05-2012, 03:10 PM   #4
wyattglock
wyattglock's Avatar
As stated before, toss the plastic. I had to replace both of my tanks due to the plastic holding rocks, mud, and water. Where they didn't rust, the rocks had started rubbing holes in the metal. But to answer your question, mine were held on by a screw that went from the top down through the strap on the bottom of the tank bracket. These also encourage the brackets to rust out, and I really don't like stopping to pick up gas tanks on the road!
wyattglock is offline   Reply With Quote
Old 12-05-2012, 03:20 PM   #5
99-LS1-SS
99-LS1-SS's Avatar
Thanks for the replies. I didn't consider the plastic trapping mud and water.
Old 12-05-2012, 08:42 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
weren't thos plastic the things that were suppoused to help in the event of a side impact? I wouldn't get rid of them but id clean them once in a while flush out mud.. they were held onto the bottom of the tank bracket with a bolt IIRC
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-06-2012, 12:16 AM   #7
Pyrotechnic
Pyrotechnic's Avatar
Looks more like skid protection, just to thicken the tank so things would have a tougher time puncturing it. Don't help much if the skid protection punctures the tank though.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-06-2012, 07:59 AM   #8
99-LS1-SS
99-LS1-SS's Avatar
Do you guys think it would defeat the purpose of the skid protection if I drilled holes in it to drain moisture out?
Old 12-06-2012, 09:35 AM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
The long black plastic piece is just a stone shield. The recall part that protects from side impact was around the filler neck (see below)
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 12-06-2012, 10:17 AM   #10
crazeetxn
crazeetxn's Avatar
There should be a bolt that holds it on from the bottom. It screws into one of the support braces.
Yes, they do hold water and mud. Found that out when mine rusted through. I just cleaned it up, drilled a few holes about 1/2" in diameter, and haven't had a problem since.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 12-06-2012, 10:29 AM   #11
99-LS1-SS
99-LS1-SS's Avatar
That's what I'll do.
Old 12-07-2012, 02:33 AM   #12
dieseldawg142
dieseldawg142's Avatar
this is what my pass. side shield looked, 28lbs of crud. this was the good side, drivers side was worse & rotted a hole in tank. i ditched mine, but if you keep 'em, defenatly drill some holes .got 2 used ones in my shop if ya want
dieseldawg142 is offline   Reply With Quote
Old 12-08-2012, 12:53 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
dam that could increase your gas mileage!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-08-2013, 09:40 PM   #14
ozkiwi
I agree both my tanks rusted out from crap caught in the plastic covers.I only drive on sealed roads so just got rid of them.
ozkiwi is offline   Reply With Quote
Old 06-09-2013, 03:07 PM   #15
pontgta
pontgta's Avatar
I left my shields on, but put some epoxy primer and painted mine black before i put them back on. I will see how they hold up.
The shields are held on by bolts attached to the tank brackets... Should be one and one on the side, then they are attached to the frame, but i just attached them to the bracket.
pontgta is offline   Reply With Quote
