12-05-2012, 03:31 PM | #1 |
6" rear drop coils???
What kind of ride quality do you end up with, using the 6" drop rear coils?
Posted via Mobile Device |
12-05-2012, 04:53 PM | #2 |
Re: 6" rear drop coils???
had them on my truck for three years before I bagged it. ...if you carry any type of heavy weight the axle will hit the frame. other than that for every day use A+!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-05-2012, 05:29 PM | #3 |
A day late and $1 short...
I have them and they ride pretty well. However, I am going to install a c-notch to give it more travel.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
12-05-2012, 06:08 PM | #4 |
Junior Member
I have heard a 4" springs with a 2" lowering block is a better ride.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
12-05-2012, 08:14 PM | #5 |
Blocks on a coil spring rear?
12-05-2012, 08:22 PM | #6 |
12-05-2012, 08:53 PM | #7 |
I have 2" blocks on mine
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
12-05-2012, 09:48 PM | #8 |
This is my 69 with a early classics 6'' rear coil... with the 2.5'' block..it's c-notched ...
[IMG][/IMG] |
12-07-2012, 09:48 AM | #9 |
12-07-2012, 11:35 AM | #10 |
Wheel tubs are still stock...though my axle is a bit close to the bottom of the bed...any lower and I would have to cut the floor....and thats not happening....if i was to do it over it would be 4'' front and 6'' rear...that would make it a bit more "driver" friendly...
12-07-2012, 11:43 AM | #11 |
the ride should be fine as the springs are made with spring rates in mind, just a shorter version of oe. the taller the spring the better tho. so a 4 inch spring and 2 inch block will ride a little better. only time ride would be a real issue would be if you cut the springs. also you will need an adjustable panhard bar to recenter the rear.
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
12-07-2012, 12:36 PM | #12 |
I have 6 inch springs also with no problems. I have heard that blocks cause wheel hop though. Or is that just on leaf spring vehicles because of spring wrap?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
12-07-2012, 12:41 PM | #13 | |
the boat guy
6" springs on my truck, it rides beter than stock empty. Withan atv or pulling a boat it sits n the bumpstops, its not too horrible as I have a lot of sidewall on my tires. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-07-2012, 12:49 PM | #14 |
6" spring 1" block with the bed off and CNotched so you can see how close it would be. Remeber this is not weighted, so it would be a bit lower once the bed is back on. Also, my trailing arms have been moved so you'd actually be about .75" lower than this.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
09-05-2015, 12:02 AM | #15 |
I know you posted this a while back. Did you have to run shims in the rear to get the pinon angle right?
