Old 12-05-2012, 04:09 PM   #1
DURG
DURG's Avatar
Stainless windshield trim removal technique?
What is the best, safest way to remove the stainless trim around the front windshield on my 65 C-10? I will be replacing the windshield and gasket. I also can get another complete set off a parts truck too but don't want to damage it. I had a hard time safely removing some of the trim from my 62 Impala SS and don't want more trouble here. Thanks.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 12-05-2012, 04:15 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Stainless windshield trim removal technique?
I took the whole windshield and gasket out first then removed the trim when I could flex the rubber on the ground.
Old 12-05-2012, 04:19 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
The trim is retained in a slot in the gasket. It can only be installed or removed after the glass is off the cab. To install the trim, the gasket is mounted on the glass and stretched to a relaxed fit. Then the trim is inserted into the slot. If the seal isn't going to be reused, in some applications it's easiest to cut the gasket apart to free the trim.
Never try to remove the trim from a windshield installed in the truck as this will bend and damage the J hook mounting inside the gasket and probably bend the visible part of the trim. When removing the windshield it is recommended to move the joint caps to one side or the other to prevent binding, and they should be left off when installing the windshield and snapped in place as the last step.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-05-2012, 05:36 PM   #4
MisterC
MisterC's Avatar
Awesome advice, as always, Mark. You just saved my arse!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 12-06-2012, 10:01 AM   #5
duallyjams
duallyjams's Avatar
If you are replacing the gasket you can use a razor knife to cut out the old one.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-06-2012, 10:06 AM   #6
kieth
kieth's Avatar
We just removed the SS windshield trim from a 65 that I bought for chrome trim only....It was so hard we had to just use a razor blade utility knife and cut the rubber from the outside of the windshield, it was sooo brittle we just took what was left out in chunks, had to bust up the old cracked windshield to get it all out without bending the trim....
kieth is offline   Reply With Quote
