12-05-2012, 10:04 PM | #1 |
Aol ?
My truck has a mild notch in the rear. My ? is can i get the axle to air out close to bottoming out on the notch with an air over leaf setup?
12-06-2012, 04:16 AM | #2 |
Re: Aol ?
Don't use air over leaf it will crack and break the leafs over time over stressing them.What year truck is it ?
12-06-2012, 06:41 AM | #3 | |
Re: Aol ?
because if no, how are you going to put an air bag on the leaf and make it come down? the only way to do that is removing leaves to make the truck sag. that isnt the right way to do it. your tryin to get your truck to lower itself more, how much lower do you need to get in the notch? |
12-06-2012, 12:33 PM | #4 | ||
Happy to be here
Re: Aol ?
You might play with adding blocks as well. On my 77 we added blocks to allow me to run more bag pressure for a smoother ride.
12-09-2012, 12:27 AM | #5 |
Re: Aol ?
I knew i could count on you N2TRUX! It's an 83 by the way. So i need to keep the 2 longest leafs on each side, right?
12-10-2012, 12:52 PM | #6 |
Happy to be here
Re: Aol ?
Thats what we did Madfish. We ran the top two leafs and it worked just fine.
12-11-2012, 11:33 AM | #7 |
Re: Aol ?
I used a 1 inch block on mine and it helped with some extra room for bags and brackets
