Old 12-05-2012, 10:38 PM   #1
bschoolz1
will these fit
http://raleigh.craigslist.org/pts/3431590463.html
bschoolz1 is offline   Reply With Quote
Old 12-05-2012, 10:48 PM   #2
DoubleL
DoubleL's Avatar
Re: will these fit
Make sure you check the diameter of the center hole. It might be too small.
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 12-05-2012, 10:53 PM   #3
GVDobler
GVDobler's Avatar
Smile Re: will these fit
The hole is too small and the backspace on the newer rims would rub against you suspension.
The hole in the older ones is big!!! And about 3 1/2 backspace was about normal.
GVDobler is offline   Reply With Quote
Old 12-06-2012, 02:48 AM   #4
blazins10
blazins10's Avatar
Re: will these fit
99 and up chevys are 3.00 bore and 60-66 are 3.5 but i had factory
ss 20s on mine for awhile , i bored the center bores out and worked fine
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
