Old 12-06-2012, 12:03 AM   #1
miltmilton
Best Headers for a 48 with a 292?
Plan on putting a 292 in my 48. Using a Clifford intake. I need help on picking the best headers for this setup which includes stock steering.
milt
miltmilton is offline   Reply With Quote
Old 12-06-2012, 04:14 PM   #2
mr48chev
mr48chev's Avatar
Re: Best Headers for a 48 with a 292?
I plan to go with the cast iron ones from Tom Langdon http://stoveboltengineco.com/catalog...417&id=1395980
There are some tube headers around that are made for the application too but I haven't looked into them.
My ongoing truck projects:
Old 12-06-2012, 04:18 PM   #3
paintman
Either Clifford or Langdon's. I havn't seen any dyno sheets to compare the two. Clifford has either shorty's or long pipe styles. I don't like the configuration of either of those though so I am planning on having custom stainless headers made for my 250. This way I can run the front pipe under the oil pan to the other side of my truck. Kind of like these. Only problem is I was quoted a price of $1,500
paintman is offline   Reply With Quote
Old 12-06-2012, 05:01 PM   #4
mknittle
mknittle's Avatar
I am eyeballing the ones at the top of the page.
http://www.cliffordperformance.net/M...gory_Code=C250
jegs has some
http://www.jegs.com/webapp/wcs/store...y+250+headders
The langondons that mr 48 posted are real nice for the traditional look.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-06-2012, 05:10 PM   #5
paintman
jegs has some
those are the shortyies, I just don't like the way the front set points back towards the driver. On my 46 I am using an under the cab brake booster and its just real tight to fit 2 exhaust pipes in between the booster and the tranny. Plus I like the true look of dual exhaust (one pipe exiting on each side of the truck) So thats why I think I'm leaning towards custom headers. actaully the pic of the headers i posted where for sale over on the Hokey forum for $100. Unfortunately someone else spotted them before me
Old 12-06-2012, 05:49 PM   #6
mknittle
mknittle's Avatar
I saw some like your picture but I don't remember where. Ill post a pic If I find them.
Mark
My GMC build.
Old 12-06-2012, 06:07 PM   #7
mknittle
mknittle's Avatar
http://prostores1.carrierzone.com/se...ers/Categories
more but I don't think the will work for paintman though.
Mark
My GMC build.
Old 12-06-2012, 06:08 PM   #8
truckeez
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. .
truckeez is offline   Reply With Quote
Old 12-07-2012, 06:54 PM   #9
paintman
This is what i'm looking for. I would just run the tube under the oil pan to the other side. To bad they don't fit a 250
Old 12-07-2012, 08:48 PM   #10
mknittle
mknittle's Avatar
Oh cast, ok there Is only one place that I know of to get them for the 250-292 they are simular to fentons.
Give the link a minute to settle it is kinda slow it will go through a couple pages and stop at the picture of the headders. I hope this helps.
I looked all over for fenton style headders for my 250 let me know if this is what you are looking for.
If i would have waited a week mr48 posted a link.lol
Mark
My GMC build.
Old 12-07-2012, 08:55 PM   #11
paintman
The langdons are not what I'm looking for. I don't want the front ports ponting towards the back. As far as I know my only option is custom.
Old 12-07-2012, 09:07 PM   #12
mknittle
mknittle's Avatar
iguess that is the only way you can get what you want. what kind are the ones you posted a pictuer of?
Mark
My GMC build.
Old 12-09-2012, 06:39 PM   #13
NEWFISHER
NEWFISHER's Avatar
Just found out today that the Langdons cast headers for a 250 in anAD will not clear the steering box. I have beeen fighting fabbing mounts etc and nada. Just sold some long tube ones last week on here that I should have kept.....dang!
NEWFISHER is offline   Reply With Quote
Old 12-09-2012, 07:45 PM   #14
mr48chev
mr48chev's Avatar
I'm not running a stock steering box so that won't be an issue for me. Is the engine setting lower than a stock engine would set or?
I went out and looked at my 48 that still has the 250 in it and the block is 7 inches from the part of the steering box that the adjustment nut and screw sit on, the top of the stock tin 250 valve cover is 10 inches below the center of the top of the arc of the recess in the stock firewall and the center of the waterpump inlet is 8-1/2 inches off the front crossmember or right close to that. The truck sits on a 54 3100 frame and uses a cast iron V8 bellhousing bolted to the stock 54 crossmember with V8 mounts.
Old 12-21-2012, 09:17 PM   #15
BLUE49
I have a '49 3100 with Langdons cast iron headers. If he knows for sure that you're putting them in a truck he will modifiy them for you. I'm very happy with everything i've gotten from Tom.
BLUE49 is offline   Reply With Quote
Old 12-21-2012, 09:21 PM   #16
NEWFISHER
NEWFISHER's Avatar
Agreed, I was fighting them and called Tom. He says " If you had told us they were for a truck, we modify them before we ceramic coat them and then ship them to you" So I cut them up, had the welded at the machine shop after cooking in an oven to 700 degrees and cooling down for 2 hrs slowly. They fit great , sound great , work great , look great, Tom is great.
Old 12-21-2012, 11:29 PM   #17
rollenhard
rollenhard's Avatar
Cool im glad i found this thread im new to the inline 6cyl scene. And ive been looking 4 some headers that will fit the 230 motor im thinking about putting these on my 50 chevy truck
http://www.jegs.com/i/Flowtech/387/11510/10002/-1
Hope they will fit
Just Cruzin Through Life
rollenhard is offline   Reply With Quote
Old 12-22-2012, 09:43 AM   #18
paintman
Hope they will fit
They sure look like a Clifford copy.
Old 12-22-2012, 11:39 AM   #19
mknittle
mknittle's Avatar
I hear if you let langdone know what the headders are going on they will shorten the front to fit.
Mark
My GMC build.
Old 12-22-2012, 11:43 AM   #20
mknittle
mknittle's Avatar
I shouldn't have problems with the Clifford shortys in my 52 or the langdons.
Mark
My GMC build.
Old 12-28-2012, 12:07 PM   #21
miltmilton
I'm really appreciative of all the replys and guidance. Looks like I'm going for the modified Langdons. After I get the truck running, I'll be investigating putting a Pontiac OHC 6 I have into it.
Old 12-28-2012, 03:43 PM   #22
mknittle
mknittle's Avatar
thatwould be cool!
Mark
My GMC build.
