Can't get the *&!$* tranny bolts loose...
So the "freeze" plug behind the motor mount is rusted through and another is about to go. I figured I'd just pull them motor, slap some new ones in, and be done with it.
After about 3 hours or so last night, I was ready to go. Got under the truck to loosen the tranny bolts and that's when the fun started. THEY WON'T LOOSEN UP!! I got the bottom one on the driver's side done, but the one right above it ain't happening. I tried 1/2" impact with 3/8" extension, universal and socket, and nothing. I was able to get my rachet and socket by itself in there, but there's no room for leverage. It's a 700r4 sittin behind a 350. I had the tranny rebuilt about 6 months ago and I think the shop used epoxy (just kidding) or something to keep the bolts in. It's driving me nuts. If I can't get it loose tonight, I'm going to see about removing the bolt on the cross-member and seein how far I can pull it up. Maybe it'll be enough to let me get at the plugs. Not unless ya'll have some suggestions?!? Thanks...
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 Last edited by crazeetxn; 12-06-2012 at 10:05 AM. |
a fool with no money
Re: Can't get the *&!$* tranny bolts loose...
I feel your pain... has happened to me several times, ended up pulling both together.
I've started pulling the motor and tranny together all the time now, regardless.
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
I know when I pulled my motor, I couldn't get those bolts either, so I just pulled the tranny too, unhook the shift linkage, the two or 3 wire plugs, the speedo cable, and undo the one crossmember bolt and pull the tranny too.
Then you can clean it up as well! Just my .02 Posted via Mobile Device |
I just pull tranny with engine too. Be a big mess if you snap a bolt.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Welp, looks like that's what's gonna happen. And here I was bustin my knuckles tryin to get the bolts out.
The linkage, cross member bolt, speedo cable, and lockup wiring is easy. Do ya'll disconnect the lines at the radiator or on the tranny? I see doing the radiator as the simplest, then just undoing a couple of brackets that secure them to the frame. Also, should I just pull the radiator out to get some more room or am I good to leave it in. I do appreciate the help. My son uses my truck to get back and forth to school and work and right now, they have to ride the bus and he waits on us to get home before he can get to work.
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
Moderator
![]() Join Date: Oct 2008
I'd yank the rad. It's expensive to replace and it comes out really easy. Dunno if there's enough room with it installed I've always pulled them.
If it's AC equipped put some plywood in between the condenser and the engine compartment.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
