![]() Join Date: Oct 2012
Need help with amp guage
Hello, my first post here. My 72 with 350 has amp guage not working.
What are some first steps to trouble shoot? Truck has hei distributor that seems to work fine. Just trying to get everything working. P.S. This site is awesome. Larry |
Re: Need help with amp guage
can't help you, but welcome to the site.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
Mine to! but my truck is a 69. Maybe someone can help us both out!
and yes welcome aboard and yes this site is awesome! Thanks to everyone on here!
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
The first thing you check: On these trucks when the alt went out it blew fuses. There are two, one is in the left front where the fender and rad support meet the other is right front same spot. They holder is about 3/4" long little rubber bullet that comes apart. If that doesn't work (which it usually does) Start looking at the printed circuit it will be meltedon that circuit.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Welcome to the 67-72 Chevy truck board!
There are two fuses that you need to check that protect the ammeter. There is one on either side of the radiator in the main harness. They are in little rubber cases that look like little footballs. The fuses are 4 amps and most of the time they are the problem. 67 to 72 are the same setup. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks Ol' Blue and Jim, I will check that out.
The p.o. installed a aftermarket amp gauge instead of fixing the existing factory gauge. I may need to run new wires. Are there pegs on the back of the factory gauge or is it feed only by the circuit board? I also have to do the temp gauge, same thing there, p.o. just added a aftermarket. The fuel gauge wasn't working either but I got that fixed by everyone's help on here! Sorry Larry, I didn't mean to jack your thread, I just saw you had a similar problem and I was hoping I could get some help as well.
How can you test the amp gauge to tell if it's working?
Mine never seem to move. |
I'd check both the fuses as mentioned above first. I think they are SFE4 about 5/8" long. The football shaped fuse holders are in the harness kinda behind the battery and down near the voltage reg. (at least mine were) Good luck to ya'.
mine had been working good since I had replaced the circuit board but was all time having to mess with it now it won't work at all. fuses are good also.
My fuse holders are where everyone says they are.And no my harness has never been messed with.Not trying to be smart. |
![]() Join Date: Sep 2011
I checked my fuses today and replaced them. Ammeter works even with a voltage regulator eliminator installed for the GM internally regulated alternator. Kind of cool.
1971 C20 "Shreck" 1980 C30 dump bed "Ratchett" |
Thanks for all the help! I replaced my fuses but amp guage still does not work.
Any more advice other than circuit board? Thanks again. I love finding out stuff like the two fuses under the hood. Also found this documented in the owners manual in the list of fuses. |
Get ahold of Vettevet he is a forum member, that dude is amazing. He could help you with your electrical problem. Sounds like a bad ground though.
Scott |
#13 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
i've seen this thread and was thinking about replying but don't PM me cause I can't post pictures in PMs. Start a new thread in the Electrics forum and we'll get you fixed up. VV
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#14 |
![]() Join Date: Jan 2012
X2 - Vettevet is a great guy. Take him up on his offer. You won't regret it.
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
#15 |
The amp gauage on my 71 c10 has not worked in the 20 years I have owned it. Never realized those "footballs" were actually fuse holders, I thought they were some type of a fusable link. Checked them today after reading this thread and sure enough one fuse was bad. I picked one up while I was out today and it now works fine! Lots of great information here!
#16 | |
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
