Electric Fans... Y in shroud?
So I saw a post here while researching about using a fan out of a Cherokee. This fan was good because it fit into the factory shroud....
My question is why does it need to fit into the factory shroud? Why not just go with a set up like this from summit? http://www.summitracing.com/parts/sum-g4908 I am thinking that with out the shroud it makes more room and clean up the bay a little. Just not sure if there is an advantage to using the factory shroud and going with the jeep fan.
Confidence is the feeling we have before we fully comprehend the situation |
![]() Join Date: Jan 2001
Re: Electric Fans... Y in shroud?
The purpose of the shroud is to draw outside air across the entire radiator, so it doesn't develop hot spots.
20' Daredevil (Ret)
![]() Join Date: May 2003
The importance of shrouds, from a recent thread on overheating:
So the one in the link wont pull the air through that is needed?
If the shroud that's included with it doesn't cover the entire radiator, it will develop hot spots outside of the area that air is drawn through.
Fabricate till you "puke"
Just a little thought on elct fan(s).....If the cooling system is up to the job, the fan or fans will not run at cruise speed, you are pushing enough air through the radiator @ 55 -65 mph to keep that engine cool! Sitting in traffic, thats a bit different on a hot day
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
