Old 12-06-2012, 07:33 PM   #1
joel.e
joel.e's Avatar
'67 door differences
Can someone tell me what is unique about a '67 door? I've been told that they are unique about the door handle but all the repops are '67-72. I'm in need of doors for my '67 so I wanted to be looking for the right thing.
Also, can you stand up the bed on its end (opposite tailgate) on your garage floor without any damage? I've seen this in several pictures and would like to do so I don't have to fix some bed supports on my back.
joel.e is offline   Reply With Quote
Old 12-06-2012, 07:36 PM   #2
BMERDOC
BMERDOC's Avatar
Re: '67 door differences
The only difference is the door handle and vent wing.The '72 is different too but thats not your question. From the outside you can't tell the difference in the handles. Setting the bed upright is fine but don't plan on doing after the front edges have been worked and in primer.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-06-2012, 07:58 PM   #3
Duncan and son
67 doors actually have two dimples where the door handles go and the inside bracket is designed for 67 only door handles. Pretty easy to change over. Other than dimples sheet metal is the same.
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 12-06-2012, 08:09 PM   #4
joel.e
joel.e's Avatar
I knew the vent windows were unique for '67 but didn't know the difference in the handle. So, I would like to keep the vent windows so do they just drop into any '67-72 door shell and nobody would know the difference?
Thanks for the help.
Old 12-06-2012, 11:17 PM   #5
Yes,the vent window assemblies interchange. The difference is in the glass frame and glass itself due to the latch not bolting through a hole in the glass.
