![]() Join Date: Sep 2002
Tach differences
I recently picked up a dash cluster with an original tach. Can anyone tell me how I can determine if it was from a 6cyl vs an 8cyl?
Any info is appreciated. Thanks! |
I think it say's on the back
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Scott,
As a complete coincidence I just received my tach-dash in the mail from Prof! Mario is right. On the back of the tach in blue ink is stamped "8 Cyl." Brian |
Binder Rep
And do you see a little switch back there to change from 6-8cyl?
I'd always heard that they were either 6 or 8, no in between or changing, but someone in the parts board said you can in his ad? |
Baradium,
I imagine that on an aftermarket tach you would be able to switch. On this factory tach, I'm not sure. There IS a little adjustment hole there, but I'm not sure if that's to trim the level precisely or if it serves some other function. Brian |
The screw in that hole on the back, is how it can be recalibrated for 6 or 8 cyl. The factory 6 tach sticker says 6cyl. I recalibrated a 6 cyl tach for my 350.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
Thanks everyone for the info. Looks like a have 6 cyl, but want to use it with a 350. Any anyone tell me how to calibrate it for an 8cyl?
If easier I'd be willing to trade mine for an 8 cyl if anyone is interested. Thanks again. |
I thought I saw somewhere on here of the number differences on the two different types of tachs...which isn't actually the tach but the lens paint, I know. Something liek the V8 tach goes 1,000 rpm higher than the 6banger...maybe someone else could shed some light on this
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
The diesel tachs are 4000 rpm.
6 & 8 cyl tachs are all 5000 rpm.
SKINNY TIRES RULE!
I've got a tach dash at home I got from my neighbor. I never knew that there was a 6 cyl & 8 cyl difference. I guess I'll have to check it out when I get home tonight. Is the stamp on the tach itself or on the metal backing?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
It is the same tach but is either calibrated for either 6 or 8 cyl. The sticker is on the back of the tach housing covering the hole to the calibration screw.
