Old 12-06-2012, 08:42 PM   #1
swells6367
swells6367's Avatar
I want to add 2" of lift
I want to lift my 73 Cheyenne 2" since my previous experience was a jeep Cherokee can I build a spring pack or will blocks do the job my truck does not see much off road mostly street time thank you in advance for your help
swells6367 is offline   Reply With Quote
Old 12-06-2012, 08:59 PM   #2
bohmankid
bohmankid's Avatar
Re: I want to add 2" of lift
2 inch blocks in the back and springs up front will get it done for super cheap.
bohmankid is offline   Reply With Quote
Old 12-06-2012, 09:23 PM   #3
swells6367
swells6367's Avatar
will this change my steering box angle
Old 12-06-2012, 09:47 PM   #4
bohmankid
bohmankid's Avatar
You will not make any adjustments to the steering box. If anything you will just need to get a longer pitman arm. a 2 inch lift will consist of 2 inch blocks in the back, u bolts, hardware, springs for the front, longer pitman arm (if needed).. oh yeah and brake lines and shocks maybe. You could probably get away without lowering the transfer case and not lengthening your driveline with a 2".
Old 12-06-2012, 09:48 PM   #5
bohmankid
bohmankid's Avatar
You can install a lift on these trucks in 8 hours if you have big jack stands, a breaker bar, and a torch.
Old 12-09-2012, 07:34 PM   #6
chevymadness
I'm in the same position I want a 2.5 lift or 2 inch if its possible I have a half ton 4x2 10 silverado.I would really like to know what springs to get in the front details please.I will be looking online to buy everything ships around here are filled with morons.
1982 chevy silverado
It's all about original guys original let me say again original.
chevymadness is offline   Reply With Quote
Old 12-09-2012, 08:14 PM   #7
cory d
cory d's Avatar
cant do too much for for 2 wheel drive. Moog # 6104 will bring the front up a little.
cory d is offline   Reply With Quote
Old 12-10-2012, 04:49 PM   #8
chevymadness
Well that's supprisingly damn useless 2x4s ain't worth a damn anyway I know I can get a 2 inch so someone needs to show me the way as what springs to buy.my front is sagging like a fat lady after 25 years of use when I hit bumps I hit the bump stops god knows how many times my fender has chipped my 31 inch mud tires on 15 inch.
Old 12-10-2012, 05:24 PM   #9
zirk
zirk's Avatar
2wd lifted !
http://67-72chevytrucks.com/vboard/s...d.php?t=442205
Chevy runs in my blood
zirk is offline   Reply With Quote
Old 12-07-2012, 01:31 AM   #10
andrewmp6
If its a 4x4 skyjacker makes a 2.5 inch lift kit.One thing i would add is a steering box brace the 4x4 trucks are known for cracking the frame around the steering box bolts.
andrewmp6 is offline   Reply With Quote
