Old 12-06-2012, 09:40 PM   #1
Marko3002
Marko3002's Avatar
Keys?
Just picked up my 72 and only have one key and it works the ignition. The key doesnt work the door locks or the glove box lock. Were there two keys for these trucks originally? One for the ignition and another for the doors? If so I need to have a locksmith make me a door key.
Marko3002 is offline   Reply With Quote
Old 12-06-2012, 09:50 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Keys?
No they only came with one key from the factory. It is likely that someone changed out the ignition at some point.
Regardless, a locksmith should be able to make you a key for the door.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-06-2012, 09:59 PM   #3
Mustard72
Mustard72's Avatar
Re: Keys?
I changed the ignition switch many years ago in my 72 C20 and lost what then became the door key(s) somewhere along the line. I just recently picked up the LMC door/ignition/glove box lock package in order to get lockable doors again. Not sure what a locksmith would cost to get the door keys made, but you might look at the LMC package to compare. Plus, one key then does it all.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 12-06-2012, 10:06 PM   #4
Marko3002
Marko3002's Avatar
Re: Keys?
Sounds like the way to go, thanks guys.
Old 12-06-2012, 10:14 PM   #5
Mister-B
Re: Keys?
Yes. It is the way to go. I just did it about a month ago. If you need help, look at my past posts. I did a thread when I did the work
Mister-B is offline   Reply With Quote
Old 12-06-2012, 11:36 PM   #6
thelonerife
thelonerife's Avatar
Re: Keys?
I bought a set of door locks,ignition,and a glovebox lock. All the same key. It was from Manes truck parts. They were only 39.00 I think.
thelonerife is offline   Reply With Quote
Old 12-07-2012, 01:13 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
Re: Keys?
see locdoc on this forum. He willl hook you up cheaper than anyone else.
WIDESIDE72 is offline   Reply With Quote
Old 12-07-2012, 07:28 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Keys?
Another option not mentioned is to remove the door locks to get the 4 digit code stamped on it. Take that to a GM dealer and have them "punch" out a new key.
Just bought a 71 Chevelle that had no keys so I took the ignition and glove locks out, got the code and new keys made.
Just another option...
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
