Old 12-07-2012, 11:33 AM   #1
mvesr
1968 step side front end conversion
I have found a 1983 chevy pick-up I can get the tilt wheel and the entire front end and other pieces from. Will the tilt wheel and the front suspension work with my 1968 stepside?
Thanks-Mika
mvesr is offline   Reply With Quote
Old 12-07-2012, 12:53 PM   #2
77shortstep
77shortstep's Avatar
Re: 1968 step side front end conversion
everything should work the column might need a little fab tho. the front suspension should bolt up also minus two holes if i remember correctly
77 CHEVY - SHORT BED STEP SIDE 2WD
02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT
77shortstep is offline   Reply With Quote
Old 12-07-2012, 01:11 PM   #3
Xeen
Xeen's Avatar
Another Option is to find a 1971-72 Longbed with tilt and swap out everything then its a direct fit.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
