Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-07-2012, 02:50 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
Low Mileage Power Steering Pump for SBC w/ LWP & Alan Grove Bracket set 402L
I bought this bracket set to install the power steering pump on the*SBC*383 in my 79 Malibu*and not have to rig up brackets to work with the headers as I have had to do in the past. Unfortunately the brackets wouldn't work*with the stock 79 Malibu pump, due to the fact that it didn't have a mounting hole in the rear of the pump, *so I had to buy the pump that is included in this auction, which is for a 75-79 Camaro/ 77-79 Caprice/ Impala.*This set up*worked great. It should fit any SBC LWP application with*inverted flare hoses.
$100 shipped to lower 48 states
I have drained the fluid from the pump. It was still nice and red, no burnt smell. I had it on the car less than 10k miles. The power steering worked flawlessly.
From The alan Grove website:
http://www.alangrovecomponents.com/i...tions/402L.pdf
402L-This bracket bolts to the front of the block and water pump boss. Mounts the pump in approximately the same position as the factory bracket without using the head or exhaust bolts allowing the use of headers.
WIDESIDE72 is offline   Reply With Quote
Old 12-14-2012, 10:27 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: Low Mileage Power Steering Pump for SBC w/ LWP & Alan Grove Bracket set 402L
Sold
