Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-07-2012, 03:05 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
383 400 SBC Chevy LWP SFI Crankshaft Harmonic Balancer 8 Inch External Balance lwp
I used this water pump on the small block engine in*my 1979*Malibu*bracket car. Unfortunately, the*engine that this balancer*was on self destructed (broken ring lands), so I am installing a milder non stroker engine, which (unfortunately for me) requires an internally balanced balancer.
There are no cracks, stripped threads corrosion or other flaws present with the balancer. There is only wear to the paint where the timing cover seal mates. I only used this*balancer for approximately 5k miles!
I could not get a good photo of the SFI stamp, but it is there.
An aftermarket hardened steel crankshaft center bolt (not pictured) as well as the three OEM fine thread lower pulley attachment bolts (pictured) are also included with this auction.
"Small Block Chevy 383 400 steel structured crankshaft damper. Externally balanced. Black Anodized 8" balancer.SFI 18.1 certified and tested at 12,500 rpm.
Perfect for racing applications. Press fit design. Dampens engine harmonics at any frequency and rpm."
$100 shipped to lower 48 states
WIDESIDE72 is offline   Reply With Quote
Old 01-15-2013, 04:11 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 383 400 SBC Chevy LWP SFI Crankshaft Harmonic Balancer 8 Inch External Balance lw
offers?
