Old 12-07-2012, 03:53 PM   #1
rwade
rwade's Avatar
After market fuel pump in a stock tank?
I was wondering if it is possible to use a walbro fuel pump (or another aftermarket) in a stock 67-72 behind the seat fuel tank? I am using an inline external pump at the moment, but would rather an in tank. And this would be less expensive than the under bed full cell route too. Any pics, opinions, and info is appreciated. Thanks
rwade is offline   Reply With Quote
Old 12-07-2012, 08:46 PM   #2
clinebarger
Re: After market fuel pump in a stock tank?
I have put a Rock Valley Fuel pump & tray in a 67-72 truck tank, Used a new tank for obvious reasons, Cut the passenger side upper corner out, Cut the tray top to fit, Made a flat patch panel for the side.....Then Tinned & Silver soldered it, A TIG weld would be a better look (I cant TIG weld).
You Can hear the pump in the cab!!!! Even after I Dynomated it.
http://www.rockvalleyantiqueautopart...o_and_kits.pdf
Heres kinda what I did....
clinebarger is offline   Reply With Quote
Old 12-07-2012, 08:55 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Do you ever have reason to come to dfw? I have the poly tank that was in my truck before I got the Boyd under Bed tank. I have both straps too, yours to come pick it up. It worked well with an external pump an EFI.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-08-2012, 01:24 AM   #4
rwade
rwade's Avatar
Its been a while since there, but my wife's aunt lives in HEB (hurst) area. Is the poly tank the "blazer" under bed tank? If so, is the fuel outlet on the bottom of tank or out of top pick up tube? If its out the top, did you ever have any problem with starving the pump?
Old 12-08-2012, 01:35 AM   #5
rwade
rwade's Avatar
Hey clinebarger, that's a clever idea. That sounds like some engineering I'd do. How loud was it inside? What did the kit with the pump cost? Thanks for the responses. :-)
Old 12-08-2012, 02:13 AM   #6
clinebarger
Very loud without Dynamat, Noticeable with Dynamat, But I could live with it.
Call Rock Valley.
Old 12-08-2012, 09:39 AM   #7
Clyde65
Clyde65's Avatar
It is the poly tank like Summit sells, I put a filler on it like a regular tank. It was just an idea if you wanted to save you some money, I never had it starve for fuel but I also don't auto rose either. I'll get you a picture if you like, ain't pretty but it ain't rusted either. The filler comes out the top
Clyde65
Rebuild of Clyde
support our troops!
Old 12-08-2012, 12:47 PM   #8
4x4toy
Just thinking out loud here. I just don't see the desire to run any high pressure fuel inside the cab. Just doesn't seem safe at all to me. I am sorry, I would never consider it.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 12-08-2012, 05:29 PM   #9
rwade
rwade's Avatar
Yes, if could post a picture that would be great. And "thinking" out loud is always helpful to me, thank you for your input. I appreciate ALL input.
Old 12-08-2012, 05:56 PM   #10
Clyde65
Clyde65's Avatar
Pm me your email and I'll send you the pix
Clyde65
Rebuild of Clyde
support our troops!
Old 12-08-2012, 10:20 PM   #11
clinebarger
On certain cars....There is NO choice, '53-'62 C1 Corvette & late 30's Chevy cars is a good example...No where to put the tank but right behind you.
