Transmission speedo thing leaks... replace or repair?
That weird thing that sticks out of the side of my 700R4 in my 87 is leaking. Its not just a speedo sensor, it is said that it also can somehow adjust for different tire sizes. I've found them here and there, they sell them at autozone and orielly's and such.
But I've never replaced one so I thought I'd ask. Do those things usually leak? Or does the leaking indicate some kind of internal problem? Is it just some kind of O-ring in there that usually goes bad? Didn't want to buy a replacement and install it before I had some kind of idea of what's going on. |
Re: Transmission speedo thing leaks... replace or repair?
Oh its called the speedometer compensator. Or speedometer adapter. Sticks out of the trans and the speedo cable plugs into it. Its something like this, although mine doesn't look exactly like it. Can't find one for sale anywhere right now.
http://www.oehq.com/acdelco-parts_15...FWaoPAodB1EAMA |
Its a speedo gear housing and its cheap...I think like $10 from jegs
I had the same problem and replacing it solved it
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
Just "Reseal" the speedo housing. You need a outer O-ring & Driven gear seal.
You have a "Ratio Adaptor", Used to correct speedo's when running over sized tires...Pic. |
Forgot the pics....
It is in fact a speedo compensator for the oversized tires. Here is a pic of mine. You can barely see the speedo cable off to the side, kinda up there in the top left of the pic. It kinda flows down and screws into the top of the thing that's leaking. That's an old pic, I already replaced the tailshaft seal.
whoops my bad...Wrong tansmission sorry
Anybody know where to buy one? I can't seem to find one for my truck anywhere right now. Oreillys, Autozone, Rockauto, nobody has any. They got other ones but not mine.
#9 | |
Moderator
![]() Join Date: Oct 2008
The part in your picture is a ratio adapter box. There's no fluid or seals inside the ratio box. It's attached to the piece you need to re-seal.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-08-2012 at 11:10 AM. |
Moderator
And please let us know if and how your repairs were successful. |
Ok cool thanks. I don't have much experience with that though. Is that something I just walk up to the counter and tell them "I need a new gear seal for my speedo adapter"? or is it something I need to order somewhere? Can't find anything on it anywhere right now which is weird cause I found them all day long about a year ago when I just thought it was the tailshaft seal. Needless to say I don't drive the truck a whole lot. For now.
Is the O-ring actually responsible for holding back any of the fluid? The guy I ordered from told me I just needed the thick orange seal.
#13 |
