Old 12-07-2012, 08:32 PM   #1
CYLFD
CYLFD's Avatar
Is this Factory ???
Is this a Factory fuel cut off ? If so might just leave it what do you think?
CYLFD is offline   Reply With Quote
Old 12-07-2012, 08:35 PM   #2
rsavage
rsavage's Avatar
Re: Is this Factory ???
That is the valve for auxiliary gas tanks.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-07-2012, 08:45 PM   #3
RHGuyettejr
RHGuyettejr's Avatar
Yep thats for the bedside gas tanks..... heres a pic.
You can see those nasty grey colored fuel doors on the side, the tanks are behind the fleetsides in front, if you look close you can just barely see the underside hanging below the bed.
RHGuyettejr is offline   Reply With Quote
Old 12-07-2012, 08:45 PM   #4
Lee H
Lee H's Avatar
Not factory but dealer installed.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-07-2012, 09:01 PM   #5
Sideways
Sideways's Avatar
I would say yes it is factory and the N40 option exactly like mine.
Sideways is offline   Reply With Quote
Old 12-07-2012, 09:02 PM   #6
CYLFD
CYLFD's Avatar
Cool deal thanks now I wonder if I should 86 it or find a cool use for it
Old 12-07-2012, 09:53 PM   #7
jocko
jocko's Avatar
I always thought the L21 was the single driver's side (factory) installation while the dual aux tanks were dealer add-ons (with no SPID callout)(?)
Sideways, do you have dual aux tanks or single? I believe the code would be left of the nomenclature (out of the above SPID pic to the left) and that N40 is pwr steering, but not positive on that. Holy cow I love that truck...
Old 12-07-2012, 09:54 PM   #8
jocko
jocko's Avatar
Absolutely keep it!! Can't get too far on a single cab tank in these things
Old 12-07-2012, 09:57 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Correct. The dual tanks were dealer add-ons. The single aux. tank was available as a factory option in 72, and the switch used to change tanks was on the dash for those units.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-07-2012, 10:30 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Here is a pic of the 72 aux fuel tank switch. It is on the left side of the dash, just above the A/C vent.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-07-2012, 10:46 PM   #11
72 K20
72 K20's Avatar
Is that an electric unit ? Vacuum ? I've never seen one of these,,, have had two with the dealer tanks in the bedside and have a parts truck with a right side poly tank that fills through the wheel well.
Learn something new each day !!!!
72 K20 is offline   Reply With Quote
Old 12-07-2012, 11:23 PM   #12
Sideways
Sideways's Avatar
Sorry ,wrong side of the spid.Mine says NL2 and I have a switch on the dash, but that only switches the gauge to tell how much is in each tank.The manual switch on the floor actually controls the flow from each tank.Oh yeah,single aux tank and the switch on the dash matches the headlight and wiper switch.
Old 12-07-2012, 11:27 PM   #13
Bill72
The single factory Aux fuel tank is RPO NL2. The lever on the floor is to switch tanks. The knob on the dash is to switch the gauge over to read the aux tank fuel level.
Sideways beat me to it.
Bill72 is offline   Reply With Quote
Old 12-07-2012, 11:32 PM   #14
Sideways
Sideways's Avatar
I could'nt have said it better myself.
Old 12-07-2012, 11:37 PM   #15
Sideways
Sideways's Avatar
If anyone has the plastic indicator bezel to sell let me know mine is history.
Thanks!
Old 12-08-2012, 01:06 AM   #16
leddzepp
Moderator
leddzepp's Avatar
Oops...I thought that it also controlled the tanks
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-08-2012, 03:16 AM   #17
jocko
jocko's Avatar
Ha, sorry - I misread the SPID - NL2 looks right, I was looking at NL2 embedded in a string of #'s and choppped off the wrong ones...
So, I'm still a little confused - I've seen many trucks that have the floor valve for DUAL aux tanks. But I've never seen one with DUAL tanks and with both switches (floor and dash). I think I was in the same boat as Scott with how I understood it.
So, Sideways - is your floor switch a 2-position switch since you only have the single aux tank?
Has anyone seen a dual aux tank truck with the 3-way floor switch AND the dash switch? I haven't seen that, nor have I ever seen dual aux on a SPID.
So (i'm saying "so" a lot...) NL2 = single driver side aux tank
and NL2 included a floor switch for flow and a dash switch for gauge reading.
How did a dual aux tank truck switch what the fuel gauge showed (since i've never seen a dual aux tank truck with a dash switch...)? Or COULD it display the other tank quantities?
Old 12-08-2012, 06:44 AM   #18
SS Tim
SS Tim's Avatar
Factory aux tanks. Saddle tank(s) were offered as dealer installed plus there were a lot of aftermarket companies and installation variations. Knew of one truck that had four tanks (cab,saddles and rear aftermarket) with 95+ gal capacity.
SS Tim is offline   Reply With Quote
Old 12-08-2012, 07:58 AM   #19
I have a '71 Custom Camper brochure that lists the auxiliary tank as an available option. I believe it's a brochure for '72s "printed" in 1971. It threw me for a loop at first.
The aftermarket (not only installed by dealers) tanks would have a three position toggle switch to control the gauge mounted where ever whoever installed it thought was best. My '72 GMC has one with an aluminum plaque with Left/Main/Right labled.
Old 12-08-2012, 08:14 AM   #20
SS Tim
SS Tim's Avatar
You must mean this one.
Old 12-08-2012, 10:25 AM   #21
ryanroo
ryanroo's Avatar
Tim, do you have pics of the inside of the bed on those options perchance? i am going to try to copycat the NL2 style in the N18 location for my relocated home made rear tank. i have a plan for the the inside of the bed, but i want to see if my plan is like the OEM stuff
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-08-2012, 11:05 AM   #22
70c10-08
70c10-08's Avatar
95+ gallons of fuel on a 67-72 C/10-30? wouldn't that hurt you more than help ya? all that weight your mpgs would really suck
70c10-08 is offline   Reply With Quote
Old 12-08-2012, 12:39 PM   #23
Sideways
Sideways's Avatar
Without checking,I believe mine has three positions and I used the third position and it acted like a theft prevention as it shut the fuel off. The dash switch only showed what is in each tank so you can check whether the second tank is full or empty at any time."So" you must make sure you have it in the correct positon for the tank you are currently using.
Old 12-08-2012, 02:17 PM   #24
Ryan
Here's the '69 aux. tank fill cover:
Old 12-08-2012, 02:36 PM   #25
Sideways
Sideways's Avatar
Would that be the same one the blazer uses?
