6.2l nv3500 into a swb k10 AM I CRAZY?
so i have purchased my first chevy, 1986 k10 swb 400ci quadrajet 700r4 3.72 12 bolt rolling on 33x10.5 ($800). previous owner gave me another front diff with purchase, i figured out later b/c he had swapped the rear and left the front axle mismatched. he also told me that it was a 350. ran the numbers found out that it was a 1978 400ci. nice truck and all but i perfer diesel, especially idi diesel, for economy and waste oil potential.
i found a 1983 GMC 1500 2wd 6.2l with 63,000 original miles for cheep ($700) so i bought it. what i want to do is swap engines and sell the gmc to make some of my money back. i know the motor mounts and bolt pattern for the trans are the same, they both have solid true dual exhaust. a good start to a project pile up. then while cruising craigslist i found a nv3500 5 speed trans that was close and was able to trade for it. now i am looking to make the 86 a 6.2l 5 speed 4x4. i can will probably get a new flywheel and clutch b/c used ones are hard to come by/trust. but i am wondering about things like the starter and if the crank on the 6.2 has a hole for a pilot bearing? drive shaft lengths? fuel systems? i plan on taking the sound deadening material and transplanting it as well as the diesel dash. am i missing anything? has anyone ran this combo? etc etc ps i know some think the 6.2l is gutless and bound to blow up. my daily driver at the moment is a 86 vw jetta 1.6l na diesel, thats gutless! |
Re: 6.2l nv3500 into a swb k10 AM I CRAZY?
The crank should have the hole for the pilot bearing, the 6.2 in my 85 burb had it and I switched it from a 700R4 to an SM-465. I think one problem you might run in to is with the flywheel...IIRC the clutch/flywheel combo I bought for my diesel ended having a 12" clutch where most gas setups are for an 10 or 11 inch clutch...somebody correct me if I'm wrong. You will need a starter specifically for a diesel and make sure you tell them its for a manual trans.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
yes the straters are diff then the gassers. and i do think that the diesel clutch is 12 inch not 10 like ont the gas.
is the nv a chevy one or a dodge one? drive shafts are ez just get new ones made to your langth. as far as the fuel sustems go swap everthing. tank filler filter ect
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
Moderator
![]() Join Date: Oct 2008
That 86 Jetta 1.6NA Diesel will get perkier if you ditch the toilet bowel exhaust manifold and headpipe. Use the pre 1980 A1 gas or diesel 6 bolt manifold. It's as good as a set of headers with the right headpipe.
Now back to GM trucks... The NV3500 is rated for 300ft-lb of torque. If you don't exceed that it'll be just fine. The Bellhousing is part of the transmission case so make sure it's from a 4.3L V6 or V8. You'll need 85-91 hydraulic clutch pedals and clutch Master cylinder. You'll also need to make a crossbreed hydraulic line to the slave cylinder.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#6 | |
I know the pieces fit
#7 | |
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
what would that be? i would love a bit more out of my 6.2
Moderator
That's why I posted that number. It's always a good idea to know the component limits. Not everyone is going to bump up the HP. If he's running a stock 6.2 and wants an overdrive stick the NV3500 is plentiful and reasonably priced.
1. Free flowing exhaust. The bigger the better but dual 2.5" or a 3" super single works good. Also chose a good free flowing muffler such as Donaldson.
2. J code intake. 3. Turn up the pump 4. Install larger precombusion chambers in existing heads or install 6.5L heads with the larger chambers 5. Exhaust headers 6. Timing gear drive 7. Port and polish heads Doing all of the above improves power significantly and best of all, increases fuel economy.
