![]() Join Date: Sep 2011
Wanted - LWB Big Block C10 Drive shaft
I am looking for a complete 2 pc drive shaft for a LWB c10 1/2 ton with Big Block, TH400 and 12 bolt coil rear. Must be complete with HD style carrier bearing and cross member mount. THX ! D'
1967 C10 SWB Owner - Rustbelt Restorations Last edited by DaHos; 12-08-2012 at 09:37 PM. |
The Waco Kid
Re: Wanted - LWB Big Block C10 Drive shaft
I have this one, LWB, heavy duty carrier, th400 to a Dana 60. Comes from a GMC 3/4 ton. Greg
Ttt
1967 C10 SWB Owner - Rustbelt Restorations |
I have one and will get a pic posted today. I believe that the TH 400 yoke is the smaller outside diameter like the 69's with TH 400 had.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
My carrier mount is like the one pictured so probably not what you are looking for.
Jim
Thanks Jim, Lynnfields looks like what I need, TH400 yoke (Larger dia. than the 350 yoke), HD carrier correct mount but I am unsure of the rear shaft length and joint style being from a 3/4T Dana 60 leaf truck.
Any more info on yours. I know there is a BB, 400, long 2pc, 12 bolt, coil driveshaft, so I was hoping to find one and NOT build one. Any help on this would be great. (even some measurements so I know what to look for)
It will b a couple of days before I can get some measurements as the shaft is stored so that I need help getting it down!
There are two yokes for the TH 400 trucks. One has a smaller od but the splines are the same. I thought the smaller one might be on some of the trucks possibly up to 72. Jim
Dave, I have one with crossmember and Turbo 400. I wasn't planning on parting with it, but for right now my truck is staying original with 3 on tree and 402 big block.
PM me if your interested. |
Still have driveshaft, crossmember and Turbo 400
$400 firm |
Active Member
![]() Join Date: Oct 2002
I have that same set up as lynnfield on my all original 68 C/10 with big block & turbo 400
12 bolt, eaton or Dana rear?
#13 |
#14 |
Loves all GMC trucks
![]() Join Date: Jul 2010
DAHOS,
I will check and see if I have the coil spring BB 1/2 ton DS from the Sierra I parted is still out there. I think its out there but I am almost positive the 2 piece shaft has a different carrier bering support. Ill get you a pic if its out there in the AM when I get off work. Mike |
#15 |
Active Member
12 bolt, 3:08 positrac
#16 |
Dahos:
The two on the right and the one on the left were on bb trucks I parted. If they will work let me know. I didn't mark them all so I can't be for sure on fitment. Mike Posted via Mobile Device |
#17 |
