Old 12-08-2012, 12:01 PM   #1
CrewCabMan
? about vacuum line
Hey guys I have switched from a edelbrock carb to a holley. The edelbrock has a big vacuum port on the carb base in the front that my pcv valve was plugged into and the rear carb base had a fitting screwed in with a short piece of metal line that the power brakes was plugged into.
The holley only has a big vacuum port in the rear. My question is can i get a tee and plumb the pcv valve and power brakes into the same port on the back of the carb? Would it be okay to run it this way?
CrewCabMan is offline   Reply With Quote
Old 12-08-2012, 12:14 PM   #2
Don SC
Don SC's Avatar
Re: ? about vacuum line
Here's a video from Holley that will help you.
Don SC is offline   Reply With Quote
