Old 12-08-2012, 03:19 PM   #1
50bomb
50bomb's Avatar
Pinion bolt
I have a 67 chevy c10 lwb with original rear end. Do not know gear ratio. But anyways I notice a leak from the pinion area. So I removed the driveshaft and am tryin to get the Pinion Bolt off but it won't budge. I am using a 1 1/8 socket with the airgun and nothing is turning. PUt alot of wd40 since Weds. I am trying to replace the Crush sleeve. I believe that is causing the leak. Any help and all is welcome. Its kickin my butt.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 12-08-2012, 04:22 PM   #2
Lee H
Lee H's Avatar
Re: Pinion bolt
Most home compressors and impact guns don't have enough power to get that nut off. You'll need to get the wheels on it and on the ground, block them good, use a breaker bar (a piece of pipe on the breaker bar or ratchet) at least 1/2 drive. The crush sleeve will not cause it to leak. I'd just replace the seal, clean up the area real good, apply a little silicon sealer to the metal lip. Make sure you lube up the rubber seal to.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-08-2012, 04:31 PM   #3
50bomb
50bomb's Avatar
Re: Pinion bolt
Yep that sounds like a plan right there. Thank you!
Old 12-08-2012, 11:05 PM   #4
oklalawnboy
oklalawnboy's Avatar
Re: Pinion bolt
Personally, I would use a new nut when i go back together. Be sure and not overtighten going back together, it is easy to do and you'll wear the bearing out. It really just has to be snug. Something like 15 inch ilbs of pressure to turn pinion and that ain't much. Tighten like a wheel bearing if that helps.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 12-09-2012, 12:19 AM   #5
crazy longhorn
Fabricate till you "puke"
Re: Pinion bolt
Yup, 15 inches of rotating tork....new bearings, maybe a tick more. But right on line with what the 1st good man had to say crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-09-2012, 01:25 AM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Pinion bolt
You can't do rotating torque spec with the diff all assembled. Mark the nut to the pinion and yolk with a center punch. Using a breakerbar remove nut if your impact wont do it. Tap yolk off and replace seal. You might need a speedy sleeve if there are some serious grooves in the yolk. Reassemble with marks lining up and reinstall nut. Tighten till all marks line up then go a little past to get pressure on the crush sleeve again.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-09-2012, 02:31 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Re: Pinion bolt
This.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-09-2012, 11:13 PM   #8
oklalawnboy
Re: Pinion bolt
You can do rotating torque if you are careful. Back the pinion up to where it isn't engaged to the ring gear (you can feel it) It will only move forward maybe a 1/2 inch before it contacts the ring gear again but enough to measure the torque it took to move it without trying to move ring gear too.
76 Monte Carlo
Old 12-09-2012, 11:52 PM   #9
ole dollor
ole dollor's Avatar
Re: Pinion bolt
be sure and put in new rear end grease when you are done, it needs to be replaced every now and then.
ole dollor is offline   Reply With Quote
