Old 12-08-2012, 07:28 PM   #1
414banger
414banger's Avatar
rim size 65 c10
going to lower my 65 fleetside 4/6 and am going with 18 inch riddler 695 i know they will be 5x5 bolt pattern but what would be backspacing and can i go with the 9.5 wide rim in back looking to get the widest tire i can in the back thanks
414banger is offline   Reply With Quote
Old 12-09-2012, 11:03 PM   #2
414banger
414banger's Avatar
Re: rim size 65 c10
anybody have any suggestions ?
Old 12-10-2012, 03:07 AM   #3
Slow Build
Slow Build's Avatar
Re: rim size 65 c10
Would you be using a stock rearend with new, or redrilled, axles or will you be using a later, and wider, rearend to get 5 lug.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 12-10-2012, 03:47 PM   #4
414banger
414banger's Avatar
Re: rim size 65 c10
i will be using stock rearend and redrilling drums and axles i want to lower it 4/6 and keep stock everything and still stuff a little wider tire on the back and is a 255/55/18 to big for the front thanks
Old 12-12-2012, 12:49 PM   #5
414banger
414banger's Avatar
Re: rim size 65 c10
hello is this forum turned on
Old 12-12-2012, 06:36 PM   #6
63burban
Chevy addict
Re: rim size 65 c10
You'll have to do the math on your own truck to get the right results. The old fashioned way is a straight edge across the face of the drum and start measuring.
63burban is offline   Reply With Quote
