Old 12-08-2012, 08:12 PM   #1
bschoolz1
removing carrige bolts without a torch
im guessing the only way to remove these bolts is to grind each one of them off with a die grinder
bschoolz1 is offline   Reply With Quote
Old 12-09-2012, 12:26 AM   #2
Captainfab
60-66 Nut
Re: removing carrige bolts without a torch
Exactly which carriage bolts are you talking about?
Old 12-09-2012, 08:40 AM   #3
bschoolz1
The bolts holding down the rails for the wood floor
Old 12-09-2012, 09:28 AM   #4
ValveTubeHead
ValveTubeHead's Avatar
If you're not intent on saving rails or wood... I found the righty-tighty technique worked best (about 60-70%); basically, tighten the bolt until it pops. I think I just used a long handle 3/8" ratchet with 8pt socket on extension. For the rest I used reciprocating saw/sawzall mostly. Cutoff wheel works well on ones that are accessible to, not so good in tight spots. dos centavos
Matt
'65 LWB Fleetside
'63 SWB Fleetside
ValveTubeHead is offline   Reply With Quote
Old 12-09-2012, 11:09 AM   #5
dwntwn
dwntwn's Avatar
I used a set of vice grips to snap the bolts that were rusty. Grab on the nut, squeeze, work back and forth a few times, the bolt is done. It didn't bend the bed strips— the holes were the original round style (not squared off for a carriage bolt like the ones they sell now) I dollied the holes that were hogged out. This way didn't ruin the wood either.
1966 c10, short fleet, 402ci 700r4
1988 r20 Suburban 454ci tbi, th400 (12v Cummins soon)
1980 shovelhead, hardtail, open primary
1998 FXDWG
dwntwn is offline   Reply With Quote
Old 12-09-2012, 02:31 PM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
"Grab on the nut, squeeze, work back and forth a few times"???????
you sure abut that???
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-09-2012, 02:43 PM   #7
Sillyoldman
#16876
Sillyoldman's Avatar
My wood was so rotten I used a hammer to knock it all out. I stood the bed up and used a grinder to cut the bolts. It went fairly fast and was easy on my back. I'll see if I have a picture.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-09-2012, 03:34 PM   #8
slorio
slorio's Avatar
My wood was so rotten that I pulled it out in chunks then used a pair of bolt cutters like you use for reinforcing wire for concrete. It cut through the 1/4" rusted bolts in record time.
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 12-09-2012, 04:55 PM   #9
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
On one project I used a mig welder, and welded a nut the top of the carriage bolt, then used a wrench on it.
On a suburban floor that I had to pull out at the wrecking yard I brought a couple battery powered drills, I can't remember the bit sizes, but I drilled a pilot hole, and then a big hole, some the head snapped right off, and on a couple that started spinning, I was able to get a socket on the back side to hold them.
Old 12-10-2012, 04:00 PM   #10
dwntwn
dwntwn's Avatar
Smile Re: removing carrige bolts without a torch
Originally Posted by ol_skool_chevy View Post
"grab on the nut, squeeze, work back and forth a few times"???????
You sure abut that???
haha!!!
1998 FXDWG
Old 12-10-2012, 09:30 PM   #11
bschoolz1
ripped out the rotted wood and used angle grinder not as bad as i thought harbor frieght
$9
Old 12-10-2012, 09:34 PM   #12
ol_skool_chevy
haha!!!"Grab on the nut, squeeze, work back and forth a few times"???????
I dont think they picked up on that.........
Mark with Chalk
Cut with a torch
Old 12-02-2018, 03:00 AM   #13
RBW
RBW's Avatar
Dredged up an old thread here. Am about to tackle removing all the bolts that are holding the metal strips over the bed wood. Some are corroded solid. The wood is too solid for easily pulling it out of the way. Looking for tips on getting those bolts out of there.
RBW is offline   Reply With Quote
Old 12-02-2018, 08:58 AM   #14
mongocanfly
Post Whore
mongocanfly's Avatar
Are you trying to save anything ? If not a torch will dl it...or a grinder with cutoff disc....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-02-2018, 12:55 PM   #15
Chevy Fleetside
Chevy Fleetside's Avatar
I used my sawsall with a metal blade.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-02-2018, 01:44 PM   #16
jayoldschool
Moderator
I uninstalled my entire bed/wood with:
- 3lb sledge
- grinder
- sawzall
jayoldschool is offline   Reply With Quote
Old 12-02-2018, 08:12 PM   #17
franken
Might want to read what was written years ago and tighten the nuts until the bolts shear off.
franken is offline   Reply With Quote
Old 12-03-2018, 12:28 AM   #18
rsd66C20
My goal was to save the metal strips. On about 80% of the bolts, i cut a "screwdriver" notch on the top with a cutoff tool. Use a screwdriver on the top, and a buddy to use an air ratchet on the nut. On some, the nut only comes down a bit and freezes, but then you can use a cutoff wheel from the top to cut the head off.
For remaining 20%, I used a cutoff wheel to get the majority of the bolt head cut off, then drilled out the center. Once you drill through a majority of the "square" part (about 1/4"), you can use a screwdriver to drive the bolt through.
rsd66C20 is offline   Reply With Quote
Old 12-03-2018, 01:18 AM   #19
RBW
RBW's Avatar
Were you cutting the heads off, in the bed, or cutting the nut and bolt shaft off from underneath? Either way, I don't get how you find clearance for the saw and get the blade against the bolt.
Old 12-03-2018, 02:04 AM   #20
mikie 1954
Get a nut buster , brake the nuts then take them off. I think I called it by the right name, it goes over the nut and you titen a wedge up against the nut till it splits.
mikie 1954 is offline   Reply With Quote
Old 12-03-2018, 11:15 AM   #21
Chevy Fleetside
When you remove the wood you can get in between the rail and bed sills. Cut off wheel works that way also, just creates more sparks. Of course this works if the wood is rotted.
