12-08-2012, 08:33 PM | #1 |
6 cyl power steering bracket pics
I have had a several requests for pics of my 6 cyl power steering pump and bracket, so instead of trying to email them all I have decided to just put them in a thread for everyone.
I have the period correct pump and brackets, the later non-intergrated head style, and the later intergrated head style. So I will start with what I have on mine which is a later intergrated head style that I cut and made fit which is actually really easy.
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide Last edited by sigshooter; 12-08-2012 at 08:54 PM. |
12-08-2012, 08:40 PM | #2 |
Re: 6 cyl power steering bracket pics
to use the later intergrated on piece head and intake style all you need to do is trim part of the bracket off that bolts to the head... I have marked this on my intergrated head pump pics.
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
12-08-2012, 08:45 PM | #3 |
close up of the part I cut off
12-08-2012, 08:47 PM | #4 |
pic of the intergrated one piece head style pump and bracket, showing what needs to be cut off to fit our trucks
12-08-2012, 08:50 PM | #5 |
later non-intergrated head 2 piece head and intake style bracket
12-08-2012, 08:53 PM | #6 |
and finally period correct bracket
12-09-2012, 12:12 AM | #7 |
very nice thanks for the info
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-09-2012, 01:38 AM | #8 |
67-72 parts collector,…
I assume this all pertains to just the 250 6-cylinders?
The 292 stuff is different.
12-09-2012, 07:05 AM | #9 |
there's a speed shop on eBay that makes power steering and alternator brackets for the 292 motor.
12-09-2012, 11:38 AM | #10 | |
The others are off 250 engines I think the 292 will fit the 250 but I am not 100% sure, I know the 292 has a notch out of it for the bypass hose but that wouldn't keep it from fitting the 250.
12-09-2012, 11:20 PM | #11 |
I see you have a 3 groove water pump pulley, does that mean a different water pump?
my motor has a 2 groove and I thought thats what was needed....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
12-09-2012, 11:24 PM | #12 |
a picture of what i got going on....just havent had much time to work on it...
12-10-2012, 12:30 AM | #13 |
The intergrated head style pump and brackets use an extra seperate pulley on the waterpump and crankshaft. I will post up some better pics of the pulleys
