Old 12-08-2012, 09:44 PM   #1
Steves72
Steves72's Avatar
antenna wire thru firewall?? wheres the hole?
Hi All,
I am replacing the heater core. while Im in here Im adding a new antenna.
My issue is I cant locate the antenna hole thru the firewall. Please Help. I have to go back together on Sunday as This is my DD.
Steves72 is offline   Reply With Quote
Old 12-08-2012, 09:46 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: antenna wire thru firewall?? wheres the hole?
Pass side covered by the cowl and just below the windshield - not on the engine compartment firewall. You need to pull the cowl to access the hole.
Old 12-08-2012, 09:51 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Here is a picture posted by JimKshortstep4x4. You can just barely see it at the bottom corner of the windshield.
http://67-72chevytrucks.com/vboard/a...1&d=1151402953
LockDoc
Leon
Old 12-08-2012, 10:09 PM   #4
Steves72
Steves72's Avatar
Thanks, I guess i will replace the heater core, and go after the wire next week.
Old 12-08-2012, 10:17 PM   #5
FLcustom10
Thumbs down Re: antenna wire thru firewall?? wheres the hole?
Here's mine:
FLcustom10 is offline   Reply With Quote
