Old 12-09-2012, 12:29 AM   #1
hpcgmc
hpcgmc's Avatar
SPID vs. VIN vs. Protecto Plate
I don't have the SPID on my GMC, but I've got a "Protect O Plate" -a metal plate that is attached to the original service manual. Can this tell me details about my truck? It had a 327 stock, but when I do a search on auto parts websites, most of them show 1967 C1500 GMC trucks as only coming with 6 cyl engines. I wonder if mine is actually a 3/4 ton, or if it was special ordered with the 327. I assumed that any 3/4 ton would have 8 lug wheels (mine has 6 lug), but I don't know that much about these trucks yet.
Here is what the plate has on it:
top line has the VIN: CE1570DZxxxxA (the "xxxx" is because I'm paranoid to reveal my complete vin)
next line: 327 0000 RXSP44 354 Y
next line: TR 435GA F07881 GMC
next line: the original owners name and the number 40-331
I found a model decoder on GMCPauls, but it only helped me determine C= 2wd, E = v8-gas and 1= 1/2 ton, the rest of the numbers in the vin don't match the GMCPauls numbers.
I'm pretty sure my dad bought it from the original owner in about 1977.
Thanks for any info.
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 12-09-2012, 12:45 AM   #2
jocko
jocko's Avatar
Re: SPID vs. VIN vs. Protecto Plate
C=2WD
E=V8 (so the 327 sounds correct)
1=1/2 ton
(the 57 has me stumped...)
0=I "THINK" it means it was a PA, MD, or NY designated vehicle
Z=Fremont plant (which makes me kinda question the 0 above..??)
The number after the Z should be a 7, I believe - for model year.
The rest=sequential production # - somewhere between 1001 and 10000 for a 67
Really curious about the "57"
Old 12-09-2012, 01:05 AM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
C = 2WD
E = V/8
1 = 1/2 TON
57 = 115" WHEELBASE
OD = WIDESIDE
Z = FREEMONT, CA PLANT
A = GVW RANGE 6000LBS OR LESS
I checked several sources to come up with this. Don't rely on just one source.
http://outintheshop.com/index.html
The link is a site where you can order a new SPID
Good Luck.
TBONE1964 is offline   Reply With Quote
Old 12-09-2012, 02:38 AM   #4
hpcgmc
hpcgmc's Avatar
Thanks guys. The numbers following the Z are C1. Is 115" wheelbase a shortbed? I'm assuming it is, cause that's what I've got.
Thanks!
Old 12-09-2012, 03:27 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Yes, SWB
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-09-2012, 01:31 PM   #6
hpcgmc
hpcgmc's Avatar
Some dumb kid painted the glove box lid, covering the SPID, back in about 1980 - oh wait, that was me! I wonder if I can remove the paint and get the SPID back?
Old 12-09-2012, 01:34 PM   #7
bruceman1968
bruceman1968's Avatar
The C is 1967 and the 1 starts the build number
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 12-09-2012, 01:41 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Try carefully wiping it down with lacquer thinner. On a 67 there may or may not be Mylar protecting it.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
