Old 12-09-2012, 09:05 AM   #1
68fixeruper
68fixeruper's Avatar
5.3 using stock ac and vintage air
Can you can use the stock truck compressor off the 2002 5.3 ( mine is a denso unit)? Then using vintage air sure fit magnun IV and tran air gm1600 adapter? What other parts are needed to make these compatible?also can you use the vintage air lines?
68fixeruper is offline   Reply With Quote
Old 12-09-2012, 09:37 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 5.3 using stock ac and vintage air
That should be all you need. Any pictures of the tran air adapter?
Hart_Rod is offline   Reply With Quote
Old 12-09-2012, 09:43 AM   #3
68fixeruper
Sorry rob i got it from nostalgic tran air sells them as well. Here is the link.of the gm1600 fitting i ordered.
http://www.nostalgicairparts.com/air...ht-out-333.php
Old 12-09-2012, 09:45 AM   #4
68fixeruper
Another guy on here used trans air adapters pt#s 313558 , 313556
Old 12-09-2012, 09:47 AM   #5
Hart_Rod
Hart_Rod's Avatar
Thanks, what motor mounts are you using? Do you have any pictures of your setup?
Old 12-09-2012, 09:52 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I hooked my stock 2002 Denso to my Old Air Products ac system, works great. I did install a TDI-nary switch to turn the fans on. I used the Docs bolts to connect the system at the compressor
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-09-2012, 10:15 AM   #7
68fixeruper
Rob im using ece mounts. I havent started my build yet still gathering parts up. The ac parts were the last parts on my list to figure out.
Clyde is it necessary to run the tdi-nary switch if im planning on using the clutch fan?
Old 12-09-2012, 01:57 PM   #8
Clyde65
Clyde65's Avatar
No it's not necessary unless you use an electronic fan
Clyde65
Rebuild of Clyde
support our troops!
Old 12-11-2012, 11:38 PM   #9
solidaxel
solidaxel's Avatar
Can I get some more info on the ECE mount, or a pic
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-12-2012, 09:11 AM   #10
Clyde65
Clyde65's Avatar
ece engine mounts
http://www.earlyclassic.com/fullImag...ion=911-GenIII
Clyde65
Rebuild of Clyde
support our troops!
Old 12-12-2012, 09:36 AM   #11
solidaxel
solidaxel's Avatar
Thanks Clyde, I am gathering parts for a 5.3 swap in my 78
LS 3 4L70E
Old 12-12-2012, 09:55 AM   #12
TopFuel1966
TopFuel1966's Avatar
Here's the stock compressor with the GM 1600 adapter in the stock mount with ECE motor mounts.
TopFuel1966 is offline   Reply With Quote
Old 12-12-2012, 10:01 AM   #13
solidaxel
solidaxel's Avatar
I guess a inch is as good as a mile on the torque side of the engine!
LS 3 4L70E
Old 12-29-2012, 10:19 AM   #14
mrhurt73
i like this mount, since the lines come out at 90 deg angle to the compressor.
but when i look up the gm 1600 part number the pictures show only straight out fittings???????
where did you get yours?
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 02-23-2013, 03:49 PM   #15
68fixeruper
Bump gm 1600 is a bust. It runs right into my frame
Old 02-23-2013, 03:50 PM   #16
68fixeruper
Old 03-15-2013, 08:02 AM   #17
68fixeruper
Wonder if this would work.
http://www.oldairproducts.com/catalo...ng-p-3865.html
Old 03-15-2013, 08:17 AM   #18
mrhurt73
thats the one i ended up buying, havent put pressure on system yet to see if it holds but it does fit.
My Projects-
Old 03-15-2013, 02:36 PM   #19
1970 C10 MJW
1970 C10 MJW's Avatar
subscribed been trying to figure out how to do ac on my ls thanks for the post man
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 05-14-2013, 10:12 AM   #20
mrhurt73
got system charged yesterday and held pressure good and 39 degree air comming out of it.
the compressor did cycle on and off often, but outside air temp was in 60's so that may have had effect on condensor.
My Projects-
Old 05-14-2013, 01:53 PM   #21
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
going to have to do this myself soon....but would probably need to change my mounts.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-14-2013, 02:35 PM   #22
mrhurt73
now important note when using the above block on LS compressor.
the LS compressor has differnet machined depths for each side, the adaptor piece is equal length.
so i used two different thickness gasket to make up the difference.
just thought i would point that out
My Projects-
