Old 12-09-2012, 01:23 PM   #1
hpcgmc
hpcgmc's Avatar
whats a quick and easy way to lower my truck?
I'd like to lower my truck a little. I'm thinking 2" up front and 4" in the rear. My truck suspension is totally stock except for "newer" shocks (I bought them 15 years ago - probably paid $100 for all 4). I have coils up front and leafs in the rear of my 67 1/2t GMC shortbed.
I'm looking at drop springs for the front for the time being (eventually I'll get drop spindles when I figure out the front brake setup I'm going to use).
Whats the best way to drop the rear? What are the pros and cons of shackels and hangers to move the mounting points of the leaf springs, vs. moving the leaf springs from above the rear axle to below the rear axle? Do I need to weld or bolt on any type of bracket to hold the leafs in place if I remount the leafs under the axle?
Thanks for all the great help on this forum!
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 12-09-2012, 01:44 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
Re: whats a quick and easy way to lower my truck?
The cheapest and easiest way to drop yr truck is to cut 1 round out of the bottom of each front spring, and 2nd get some blocks and longer Ubolts for the the rearend, you can get the block kit at Advance Auto Parts.
Best of luck,,
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 12-09-2012, 01:59 PM   #3
Boog
laying low
Boog's Avatar
Cutting one coil off the front will get you about 2" of drop. Now the rear is another story since you have leafs. Blocks won't be of help since the springs are over the axle. Adding blocks will actually lift the rear.
If you flip the axle to over the leafs it will net you more like 5 to 6" drop, more than you are asking for.
Your better bet for the rear is shackles and hangers to get closer to the 4" you are asking for.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-09-2012, 02:13 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Shackles and hangers can give you a 4-inch drop. It's what I have on my '96. If you go 5 inches or more, you'll probably need to C-notch the frame.
Member Nr. 2770
Old 12-09-2012, 06:54 PM   #5
BatteryMedicJoe
BatteryMedicJoe's Avatar
Get a fat girlfriend
"We always have parts left over on a job this size"
1971 GMC 3/4 572 big block
1988 GMC 88,000 miles
BatteryMedicJoe is offline   Reply With Quote
Old 12-09-2012, 07:00 PM   #6
Sicklajoie
The Niner
Sicklajoie's Avatar
Let the air out of your tires.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 12-09-2012, 07:03 PM   #7
Sideways
Sideways's Avatar
How about twenty bags of portland cement?
Sideways is offline   Reply With Quote
Old 12-09-2012, 07:03 PM   #8
Daddy'O
Daddy'O's Avatar
Ha! - I was going to suggest letting the air out of the tires...........
Seriously - Check out Early Classic Enterprise - they have quality stuff and good information on lowering our trucks.
Good luck!
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 12-09-2012, 07:06 PM   #9
Daddy'O
Daddy'O's Avatar
You beat me to it -
Cheers - Wayne
Old 12-09-2012, 11:28 PM   #10
hpcgmc
hpcgmc's Avatar
Thanks guys, I'll go pick up a fat chick to ride in the passenger seat, 20 bags of cement in the bed, and flatten the tires, while I drive around town looking for shackles and hangers.
I'm actually checking with Early Classic to see if they have a front coil/ rear leaf drop kit that includes shocks - I figure if I break up with the fat chick, what I save on food I can spend on a lowering kit.
Edit - Early Classics doesn't seem to have hangers, just brackets, so I'm still searching. If I lower the rear 4" and the front 2" via shortened coils up front and shackels/hangers in the rear, will I need new shocks?
Old 12-10-2012, 09:34 AM   #11
Yes,you'll need new shocks. Personally,I'd buy a pair of 2" lower coils for the front. Removing the springs is no piece of cake and I'd rather "gain" a good ride rather than "kill" it for my effort. They don't cost much at all.
Old 12-11-2012, 11:35 AM   #12
hpcgmc
hpcgmc's Avatar
Does anyone know where I can get 2" lowering shackles and 2" lowering hangers for my rear leaf springs? ECD only has 1.5" lowering shackles and no hangers, and other places I'm checking don't carry either of them. I can't afford the $400.00 for the rear drop leafs that ECE carries.
Is there a reason that these lowering hangers and brackets are hard to find? Is there an engineering or design problem that makes these difficult or impossible to use on these trucks?
$125 for 2" front drop coils is a good price, but won't do me any good with a stock height rear end. Maybe I'll just have to stay stock while I save up some cash.
Old 12-11-2012, 12:29 PM   #13
CC69Rat
CC69Rat's Avatar
Maybe Nate Porter could make you some or might know where you could get them? He might chime in ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-12-2012, 11:25 PM   #14
That stuff is readily available for '73-up trucks. Look into seeing what's involved with using that on a 67-72. I'd think you could use it.
Old 12-13-2012, 02:48 AM   #15
hpcgmc
hpcgmc's Avatar
Wes at Classic Heartbeat told me that the shackels don't work well with the leafs because they hit the bottom of the bed and sills. He has a leaf flip kit for a reasonable price, but my truck has 9 leaf springs! I assume when my dad had the rear end changed (after I blew the rear end burning rubber in high school) they put in a 3/4 ton rear end, including the leaf springs. That also explains the very low gearing on the truck (when I had 31" tires, I was still running 3 mph fast on my speedo).
SpecialK - I thought about the 1973 rear axle, but that would give me a wider rear end and 5 lug wheels (I've got 6 lug and I'm keeping that for now). Plus, I think I'd still have the problem with the shackels hitting the bed floor, if Wes is correct.
If I have only 5 leaf springs, that should only lower my truck about 4-5" on an axle flip - can I just remove 4 of the springs from the spring pack - or is this asking for trouble? The truck won't be used for towing or much hauling, other than a couple dirt bikes on occasion (under 1000 lbs in the bed).
Old 12-13-2012, 08:49 AM   #16
I'm not talking about using the later axle,just the lower hangers and shackles. You do have to watch the bed clearance using both. You can also try removing leafs. Basically,you can achieve about the same thing as those pricey ECE leafs. You could also keep an eye on the parts board and Craigslist for used stuff to save money. This stuff used usually doesn't have much wear on it.
