Transmission throttle linkage clip
Hello,
I've been reading on this forum for about a month now. I purchased a '72 c10 and am working on small things here and there. We are friends with a hot rod/kustom shop down the street, and anything I can't handle they usually help us out. My transmission linkage cable was not hooked up to my carb at all when I got the truck. I purchased the bolt needed to hook up to the carb, but the plastic clip on the cable itself is cracked on one side so it falls off as soon as I let off the accelerator. anybody know where I can find JUST the clip? I've got a lot of slack on the cable and could cut it off and remount it. I also don't know what it's specifically called, so maybe somebody could help point me the right way. if I need to post a photo of the part let me know and I'll go snap one later or tomorrow. thanks in advance, -Alex |
Re: Transmission throttle linkage clip
better off just to replace the kick down cable
less than $40.00 very easy to install
Fuzzy |
Rusty Nuts
Auy parts store should have them, I got one at oriellys about 2 months ago. It fit good.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
#5 | |
There's an o'reily's a few miles away and those dudes are super helpful, i'll give em a whirl. thanks! |
![]() Join Date: May 2012
welcome from Texas. hope you find the part you need...lots of good info. here.
#7 | |
![]() Join Date: Oct 2001
#8 | |
Them outside and showed them and the guy knew exactly what It was. It came from edelbrock and it was 10 bucks. Posted via Mobile Device |
I ordered my bolt kit from Jegs. I got extra clips online from a transmission shop.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
Ok, I'm confused. There's a tranny cable that goes to the carb? What does it do, control downshifting?
#12 | |
Every vehicle has it, but mine does and yes, I'm pretty sure That's what it controls. Posted via Mobile Device |
#13 | |
Cluster King
![]() Join Date: Nov 2012
700R's also use a cable but it controls all shift points related to throttle position. Hope this helps |
