Installing k5 4x4 axle housings onto 66 swb
Is there any information on installing k5 4x4 axles & housings onto a 66 swb frame. Thanks for any help
Re: Installing k5 4x4 axle housings onto 66 swb
I look at that but I don't see information on installing K5 blazer axle housings onto the frame of a 66. Am I missing something
nothing special I just happen to have a K5 and a 66 I just wanted to make my 66 a 4X4 Thats all
#6 | |
ron |
#7 | |
I presume that you are also going to use the blazer suspension. there is a difference in spring size depending on which year it comes from. In Jon's applcation and the other they are from 73-87 variety except for Jon's. they used that suspension until 91 in suburbans. ron |
I may have overlook the part where it talked about swapping axles in the thread My K5 is a 76. I will go back and look at the thread again. Thanks
this is a "K"5 application that was installed on this 65 gmc frame
helps when you put in the link http://67-72chevytrucks.com/vboard/s...d.php?t=555508 ron |
here is some more pics of the spring hanger install. this is the later p/u or k5 spring setup
![]() ![]() ![]() ![]() ![]() ron |
