Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-09-2012, 09:05 PM   #1
68Redhead
Drill bits/Reams?
Hey everyone, where do you get your drill bits/reams from? I'm needing to purchase some so I can put some holes in my frame! A bottom cut 3/8 ream would be ideal for my No Limit relocators. The place I work at has a machine shop so surely they can make a ream into a bottom cut if I need to go that route lol
68Redhead is offline   Reply With Quote
Old 12-14-2012, 06:29 PM   #2
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Re: Drill bits/Reams?
got to them and get an msc catolage or go to msc online and order what you need. best place for all metal working supplys. just dont but cheep chinese junk. spend the $$ and get quality drills. then use them in a corded drill and not to fast to burn them up. will last a long time. use cuttting oil too.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 12-14-2012, 09:28 PM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I've been use'n Cromate bill bit's and hole saw's, best I've ever seen. just drill'd a couple dozen 5/8 hole's in my frame, last hole went as quick as the first.
not sure on the cost, mine were issue'd to me.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-15-2012, 03:27 AM   #4
Gumby
Gumby's Avatar
not in that size but I grab 2 packs of these a year for starter holes [then I use a step bit for the size needed]
I love the hex shank and they do work well and last for many many holes, toss away when dull.
13 Piece Titanium Nitride Coated Drill Bits
http://www.harborfreight.com/13-piec...bits-1800.html
Drill Master - item#1800
Titanium nitride drill bits last longer and run cooler
Availability: In stock
Sale: $6.99
Gumby is offline   Reply With Quote
Old 12-16-2012, 12:19 PM   #5
ETsC10
Hand Crafted C-10
ETsC10's Avatar
So, what you need are blind holes?
As for easy to find cutting tool brands, I like Irwin.
With the proper speed & feed, they last me just fine.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
