not enough hours in the day
Engine Identification
I'm trying to figure out what engine is in a new project. The front pad is stamped with F06I7M and the rear of the block was cast with 3849352.
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
![]() Join Date: May 2012
Re: Engine Identification
some one will chime in and id that number for you, i have looked and can't find the link, but i will look some more...
i found a # 3849852 that is a 1964 to 1968 283 from 195 to 220 horse power. and a 2 bolt main....did not find a # 3849352..double check your # and see if its an 3 or 8....
#4 | |
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
I have also been finding that 3849852 goes back to '58.
"M' also decodes to a '58 283 in a truck with a manual trans. I would look for a Date Code next. It will also be on the back of the engine and will be between what looks like 2 Slotted Screw Heads. Bill
I'll do a little more cleaning and try to get a better look. The engine is still in the vehicle and it's a little hard to see.
I double checked the number and it is 3849852 as suggested. I haven't been able to find the date code. Is it in the same area?
CHEVY/GMC VIN DECODERS |
Thanks Bruceman
The Date Code can also be on the Flat Part, like how the Casting Numbers are, but either next to it or on the other side of it.
