Old 12-10-2012, 01:55 AM   #1
c10boob
c10boob's Avatar
Upper Ball Joint Installation
I have a 71 2WD with disc brakes and am trying to replace the upper ball joint. I have already removed the factory ball joint, but when I install the new one I can still see some of the ball joint's shaft showing between the upper control arm and steering knuckle.
I tried using a ball joint press but damaged the ball joint in the process, and was told by an O'Reilly Auto employee that the upper ball joint does not need to be pressed in, and should go into place when being bolted on.
Secondly, it looks like the hole for the cotter pin is going to be quite a bit below the cotter pin nut..
Any thoughts and/or advice?
c10boob is offline   Reply With Quote
Old 12-10-2012, 06:28 AM   #2
Re: Upper Ball Joint Installation
The upper ball joint is bolted in. You have to grind the rivets off the orginal ball joint, then the new ball joint bolts to the upper a-arm.
Old 12-10-2012, 06:42 AM   #3
darkhorse970
darkhorse970's Avatar
You will need to ensure that you have the correct ball joint for the spindle that you are using. Are your spindles stock? WHat manufacturer and part number are the ball joints?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 12-10-2012, 06:43 AM   #4
c10boob
c10boob's Avatar
Yeah I've got that part, but am having trouble with the spindle that inserts into the steering knuckle. How did you get yours properly seated?
Old 12-10-2012, 06:54 AM   #5
c10boob
c10boob's Avatar
Darkhorse: My suspension is all stock at the moment, and the ball joint is MasterPro part K6124 http://m.oreillyauto.com/mt/www.orei...ord=ball+joint
Old 12-10-2012, 09:15 AM   #6
DorianB
DorianB's Avatar
You may have the wrong year ball joint.
Over the weekend I tried to put a 72 spindle on my 68 and I have exactly the same symptoms you are talking about. The upper ball joint bolt doesn't sit down inside the spindle completely to fit.
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2
DorianB is offline   Reply With Quote
Old 12-10-2012, 10:14 AM   #7
c10boob
c10boob's Avatar
Interesting. Ill double check it. So I'm not nuts though.. this thing should taper into the hole without using an extreme amount of pressure right?
Old 12-10-2012, 11:03 AM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
The ball joint has to match the spindle.
So does the outer tie rod.
Breaks down as follows:
63-70
71-72
73-87
Keith
Convert to disc brakes.
Old 12-10-2012, 03:39 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
One more tip.When you put the bolts in,the nuts go on top of the control arm.The heads of the bolts are thinner and wont interfere with the ball joint like they will if you put them nuts down.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
