Old 12-10-2012, 03:13 AM   #1
FloatMonkey
FloatMonkey's Avatar
Fender Question
So I got my 1970 GMC truck back from the body shop and the right front GMC V-8 1500 emblem was on crooked and the front chrome eyebrow piece does not fit correctly either. I know there is a differece between the Chevrolet and GMC fenders, what are those differences?
FloatMonkey is offline   Reply With Quote
Old 12-10-2012, 08:21 AM   #2
hugger6933
Re: Fender Question
The differences would not effect your problems. The boy lines at the front of the GMC are different like a 68 Chevy around the front grille opening where the moulding attaches. Most likely it they have installed a new fender, the holes are not there if I remember correctly. So they had to have drilled them at them shop, or they[the holes] were there and the stamper put them in crooked and that idea is not far fetched either. Jim
hugger6933 is offline   Reply With Quote
Old 12-10-2012, 12:08 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Fender Question
The fender emblem is a quick fix, elongate the stud holes a little. The emblem should hide the holes. As far as the eyebrow goes if it is a repop it probably won't fit worth a dam as the stamping is junk. Loosen the nuts inside the fender and move it around until your happy. I spent several hours getting mine where I wanted them to be.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
