4x4 Leaf spring anchor plates
I have a set of front and rear leaf spring anchor plates I purchased from another member, but were not the right ones. I decided to clean them up and post them for sale. I wire wheeled, preped with a metal etching solution, primed and used three coats of flat black rust preventative paint. $85 plus shipping.
Posted via Mobile Device |
Re: 4x4 Leaf spring anchor plates
Ttt
Ttt
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
![]() Join Date: Oct 2011
why wouldnt they work? what springs did you use that they dont fit?
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
I swapped my axles out and used 73 axles, plus these I believe are going to be for a dana 60. The rear plates would have been fine but I have square u bolts they will only work for someone who has round ubolts that go from the bottom up, or someone that wants to swap out square ubolts for round ones. I will provide measurements for anyone interested so someone else doesn't get stuck with them.
Ttt
Ttt
Still for sale
Bump
