68 C20 gas question
How do I find out what type of gas my engine uses? I inherited a 68 C20 and I am not sure what gas it uses (Leaded or unleaded)... How do I find out?
If it DOES need leaded gas will running it with unleaded gas hurt the engine? The engine is a 250 streight six 4.1L Thanks for your help! Chris |
Active Member
![]() Join Date: Oct 2002
Re: 68 C20 gas question
If I remember correctly they stopped selling leaded gas around 1980, so if your truck has been on the road sense then...
![]() Join Date: Apr 2007
Regular grade unleaded should run just fine.
![]() Join Date: Oct 2011
it should run fine on pump gas. im told you want hardened valve seats if you ever rebuild the engine. and no, i dont know what is involved with that...lol
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
![]() Join Date: Jan 2001
Tetraethyl lead, which was formerly added to gasoline as an antiknock agent, had the added advantage that it acted as a lubricant for valves, particularly for the exhaust valves. As burb71 stated, it's been gone for a very long time. If your engine were going to be damaged by a lack of lead in the gas, it would have happened by now.
Regular gas will be fine. The biggest problem you will have is not from the lack of lead, but from the addition of ethanol to gasoline. Ethanol is not friendly to fuel system components that weren't designed for it. When you get to the point where you need to replace fuel system components, particularly a carb rebuild, make sure the parts are compatible with e10, which is 10% ethanol and is the gasoline you'll find almost everywhere. |
![]() Join Date: May 2012
just fill her up and drive....have fun with it.
Thanks everyone! Looks like I was a little too worried about it.
![]() Chris |
