Old 12-10-2012, 02:42 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Lower Ball Joint Nut???
Ok, so I got the new drop spindles painted, brake backing plate installed and went to go install them and the upper ball joint nut went on no problem but the lower ball joint nut doesnt want to go on... The threads dont appeared to be buggered up and I even tried grabbing the nut from the other side (which is also disassembled) and neither of them want to go on. It goes on about 6 threads and then the whole ball joint turns...
Any ideas on how to get it all the way down???
tex_waco_usmc is offline   Reply With Quote
Old 12-10-2012, 02:48 PM   #2
Lee H
Lee H's Avatar
Re: Lower Ball Joint Nut???
Sounds like the threads on the joint or the nut have a bur. Try an old nut. You may have to chase the threads.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-10-2012, 02:51 PM   #3
tex_waco_usmc
Thats what I was thinking! Not what I wanted to do but hey, Stuff happens!!!!
Old 12-10-2012, 03:03 PM   #4
Lee H
Lee H's Avatar
Try tapping or jacking up slightly on the lower arm to get the taper to seat and try to tighten it
Old 12-10-2012, 03:05 PM   #5
tex_waco_usmc
Im going to give that a shot this evening and see where it gets me!
