Old 12-10-2012, 04:31 PM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
Exclamation Gas gauge issues
My gas gauge isn't reading anything and the needle limp. I have two good verified gas gauges my printed circuit board is good and my switch was working fine last week. All I did was change my mechanical oil press and water temp gauges to sunpro and drive it for a week with no gauges. I don't know what the hell is going on but with the way this thing eats gas I NEED my fuel gauge working
It's an 86 with duel tanks if that helps
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-10-2012, 04:58 PM   #2
Gigem
Gigem's Avatar
Re: Gas gauge issues
bad ground?
Gigem is offline   Reply With Quote
Old 12-10-2012, 05:19 PM   #3
hyatt
remove sender wire at tank Guage should go past full Ground sender wire guage should go past empty If not guage or wire to guage bad
hyatt is offline   Reply With Quote
Old 12-10-2012, 06:41 PM   #4
spencer_41188
spencer_41188's Avatar
anyone have the wire diagram for the dual tanks my 88 was efi but the guy i got it from changed it over to carb it would be nice to get both tanks working and the gauge reading
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 12-10-2012, 06:44 PM   #5
INSIDIOUS '86
I pulled the gauge and have two other good gas gauges that I jumped directly to the harnes plug and still no gauge movement or anything and I doubt that both sending units in both tanks went completely bad at the same time. I can flip the switch and hear the diverter valve working so the switch still has to be good idk what else it can possibly be
Old 12-10-2012, 07:19 PM   #6
hatzie
Moderator
hatzie's Avatar
See my signature...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 12-10-2012, 07:19 PM   #7
1981Stepside
1981Stepside's Avatar
When you say you jumped them directly to the harness plug, do you mean the harness into the instrument cluster or the harness on the diverter valve? If you mean the instrument cluster, you might have a break in the wire between the fuel tank and instrument cluster. Trace the wire from the fuel tank to Tue selector valve and jump it there, and work your way forward.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 12-10-2012, 07:43 PM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
when you painted the skull on it you killed it lol
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 12-10-2012, 07:55 PM   #9
hatzie
Moderator
hatzie's Avatar
I assume you checked the ground and power harness splices behind the instrument panel.
In 86 the valve picked which sender feeds the gauge. At the valve plug the solid pink wire is the gauge feed and the pink wires with stripes are the senders.
Unplug the valve and switch the ignition on. If this nails the gauge at 3:00 then the pink wire is OK.
Bypass the valve sender switch as a test.
Jumper the Right Hand sender wire, Pink with Black stripe, to the Solid Pink wire using a jumper wire and the proper mating gender weatherpack pins. Check the gauge with the ignition on. Repeat for the Left Hand Sender wire.
If this works the switch inside the valve has gone bad. If not you narrowed it down to one or both sender wires.
Old 12-10-2012, 07:57 PM   #10
hyatt
If wire was broken between guage and tank it would read past full Remove the dash guage and with a test light and key on 1 terminal should check hot Then clip the test light to a hot termimal and touch the other 2 terminals 1 should light the light bright It will be the ground Touch the third and it will probally light dimmer or slight pulsate where sender is reading ground resistance It sounds like you have either no 12v or no ground at the guage
Old 12-10-2012, 08:19 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
Yes,
sender off
should be over full
grounded would be E
if no movement,I'd confirm the power and ground to gauge are good
sounds like a good time to bypass it and have a manual choice of which tank to read
good for those Earnhardt pit stops lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-10-2012, 09:29 PM   #12
88Jimmy4x4
88Jimmy4x4's Avatar
did it work before you took apart and painted on it?
1991 GMC Jimmy 4x4
Old 12-10-2012, 10:49 PM   #13
INSIDIOUS '86
Yah it all worked fine before everything pulled apart. All I changed was the gauge face and the Equuis gauges with sunpro and then added a clock.
When everything is plugged in the needle is limp like there is no power if I hit the switch to swap tanks nothing happens but you can hear the diverter valve work and it was working last week. Hatzie I looked earlier in your sig and didnt find much for wiring stuff since my iPhone wont show it all
Old 12-10-2012, 10:56 PM   #14
hyatt
check your printed circuit at the back of the guages at the silver snap in clips You are not getting 12v or ground also check your guage fuze
Old 12-10-2012, 11:41 PM   #15
INSIDIOUS '86
I'm getting gauge lights but is there a diff fuze for gauges? I checked circuit board for continuity and it checked out. But I'm not getting 12v off the fuel system wiring from the clip that goes to the gauge bezel
Old 12-11-2012, 12:38 AM   #16
hatzie
Moderator
hatzie's Avatar
Try this.
ST_352_86_1986_Chevrolet_GMC_Light_Truck_Wiring_Manual_CK_10_30_Only.pdf
Old 12-11-2012, 08:19 AM   #17
hyatt
yes there is a guage fuze
Old 12-11-2012, 05:11 PM   #18
INSIDIOUS '86
Yah the fuze keeps blowing idk why
Old 12-11-2012, 05:24 PM   #19
hyatt
First thing Unplug the big plug from cluster and replace fuze If it blows you have wiring problems in main harness If not short is in cluster I would check is where you installed the aftermarket guages in the panel Check and see if they are shorting against the origional printed curcuit
Old 12-11-2012, 05:30 PM   #20
hyatt
I noticed you had a factory tach If you added that to your cluster without changin to matching printed curcuit you will have all kinds of problems
Old 12-11-2012, 05:38 PM   #21
INSIDIOUS '86
It's fixed there was a wire rubbed raw and shorting and blowing the fuze.
Hatzie the diagram was helpfull thanks for the help guys Ile get pics up when it's all together
Old 12-11-2012, 06:33 PM   #22
INSIDIOUS '86
Finished product
