Old 12-10-2012, 06:40 PM   #1
Rob68c10
What do I need to change to drop a small block in where a big block was?
Looking at a 84 ish suburban that had a 454 in it but it all got pulled. Found a 383/turbo 400/tcase for 1200 bucks. What will need to be changed motor mount wise?
Rob68c10 is offline   Reply With Quote
Old 12-10-2012, 07:09 PM   #2
baclay9
Re: What do I need to change to drop a small block in where a big block was?
Nothing
baclay9 is offline   Reply With Quote
Old 12-10-2012, 07:17 PM   #3
C-10 simplex
What about exhaust?
C-10 simplex is offline   Reply With Quote
Old 12-10-2012, 11:09 PM   #4
86c20
86c20's Avatar
use small block manifolds if that is what the 454 had and it will bolt right up i think. the monts on small/ big blocks are in the same spot it is just infront of the motor mounts that is diff.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 12-10-2012, 11:45 PM   #5
hyatt
motor mounts will work trans will bolt up you will have to fabricate exaust and all your brackets will have to be for small block
hyatt is offline   Reply With Quote
Old 12-11-2012, 02:01 AM   #6
Redcap
A big block.
Redcap is offline   Reply With Quote
Old 12-11-2012, 08:05 AM   #7
BigBlocksRule
This I'd like to see!!!
BigBlocksRule is offline   Reply With Quote
Old 12-11-2012, 01:16 PM   #8
bigblock73
yeller
bigblock73's Avatar
What are the Vegas odds on this...cause I am in for making some $$
bigblock73 is offline   Reply With Quote
Old 12-11-2012, 01:33 PM   #9
Redcap
Never seen a big block, eh?
