![]() Join Date: Feb 2012
350 manual Trans, swaping to automatic HELP!!!
hey every one.
Well the motor that came with my truck was a 350, did some research and its from a 1969 Corvette 300hp. and it came with a Saginaw 3speed well I took the Trans apart and they ran it with out no gear oil. Well its shot lol. I was wondering what do I need to make it a automatic?? And what would be the best tranission to use ; it would be a daily driver. Thanks guys My truck a 1965 gmc . I got donor parts from a 1977 c10 (rear end,& front cmember) Posted via Mobile Device |
#2 | |
Re: 350 manual Trans, swaping to automatic HELP!!!
1. rear axle ratio 2. tire diameter (ground to top of rear tire) 3. your email address (pm this to me) I will send you a spread sheet which shows torque and speeds with your rear axle ratio for all of the above transmissions and also turbo 350 & 400 trans missiions (direct drive in final gear) Kieth |
I will Kieth thanks
