Old 12-11-2012, 02:33 AM   #1
BIGBLU 72
BIGBLU 72's Avatar
LWB performance limits
Someone please tell me that I can get similar performance out of my long bed compared to a short bed in terms of handling. Plan is front/rear sway bar, good shocks, lowered (2.5/4).
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 12-11-2012, 08:27 AM   #2
hugger6933
Re: LWB performance limits
You might give up a little bit of hadling going to a longer wheelbase length but not very much, prbably not enough to feel you would need electronic measuring devices to tell the diferences.
hugger6933 is offline   Reply With Quote
Old 12-11-2012, 08:43 AM   #3
68Stepbed
68Stepbed's Avatar
Exactly what kind of "handling" are you referring to? Are you talking spirited driving on back country roads or extreme stuff like autocrossing and road racing?
If you're just talking spirited driving, then you won't be much comparable difference. If you start autocrossing or road racing, then yes, the longer wheelbase can start making a difference. A long bed chassis will tend to twist and flex more than a short bed chassis, and the longer wheelbase will make it harder to weave through cones.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-11-2012, 09:10 AM   #4
CC69Rat
CC69Rat's Avatar
why 2.5/4 ? Can you go down a little more ? I understand you can get them too low for handling performance .. but I'd do maybe 4.5/6 ?
Trailing arms or leafs?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-11-2012, 02:11 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The words "truck" and "handling" don't go well together. Short or long bed. If you're lookin' for a corner carver... you'll have to sink some cash into it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-11-2012, 04:17 PM   #6
BIGBLU 72
BIGBLU 72's Avatar
It's a leaf spring truck and no autocrossing but blasting down back roads, btw these will be Eastern Ky back roads. I didn't want to go too low bc our roads are rough, real rough. I don't want to do any serious modifications frame wise either. The truck is done now in just addin bolt on stuff.
Old 12-11-2012, 04:39 PM   #7
68Stepbed
68Stepbed's Avatar
It'll be fine for that and there won't be any major advantages of a shortbed for that use, other than looks.
Just an FYI, even with a 4/6 drop, it still sits higher than most modern FWD cars today, so rough roads still won't be a major issue, unless these roads you mention are too rough for a FWD car.
Matt
Old 12-11-2012, 10:15 PM   #8
BIGBLU 72
BIGBLU 72's Avatar
Coil spring srry!
Old 12-11-2012, 10:29 PM   #9
CC69Rat
CC69Rat's Avatar
No frame mods required for 4/6 drop.
Chad
Old 12-11-2012, 10:37 PM   #10
jocko
jocko's Avatar
Gary
what he said. It can be done, but if you want serious handling, it's a full suspension re-do. If you want a slightly more smoothe truck, then that's not very hard to do at all - sway bar(s), better shocks, lower (cg), etc.
Old 12-12-2012, 08:46 AM   #11
68Stepbed
68Stepbed's Avatar
Gary
Not necessarily. Alot of guys at the GG autocrosses are doing very well, with only simple drop kits and sway bars. The coil spring rear setup on 63-72 trucks is actually highly capable. Keep in mind that NASCAR chassis' use almost the exact same setup. Of course with autocrossing becoming more and more serious, the 50 yr old suspension design it's showing it shortcomings. This is mainly in the front setup, though. There are improvements to be made in the rear, like stronger tubular trailing arms, better angles, better swaybar geometry and such, but for the most part, the stock stuff can hold it's own.
The biggest drawback to the coil spring rear suspension is it's lack in being able to haul as heavy loads as a leaf spring setup.
Matt
Old 12-12-2012, 09:11 AM   #12
steelhorse
steelhorse's Avatar
Hey didn't a truck baisically win muscle car of the year in Hot Rodding magazine?
steelhorse is offline   Reply With Quote
