Old 12-11-2012, 04:14 PM   #1
RLONG
RLONG's Avatar
Rearmain
Anyone know how hard to replace rear main in 70 blazer 350,4x4 ?
RLONG is offline   Reply With Quote
Old 12-11-2012, 09:05 PM   #2
LONGHAIR
Re: Rearmain
It's not that bad on a 4x4, since there is no crossmember under the oil pan. It's just a matter of removing the few simple things that may be in the way....and that would depend up which transmission you have (stick or auto). Sometimes the exhaust may be a bit in the way, but usually not. Then it's a simple as dropping the pan and rear main cap. "Rolling" the upper half out and back in is easy. Put the lower half in the cap.....and it all goes back together.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-11-2012, 09:20 PM   #3
RLONG
RLONG's Avatar
Re: Rearmain
thanks i will try it.
Old 12-11-2012, 10:08 PM   #4
69GWC
Re: Rearmain
You will have to jack the front of the motor up untill the dizzy hits the fire wall (take off the cap) then unbolt the motor mount and cross member and push it as far forward as you can and I believe its the number 2 cylinder that you put to TDC so the pan will clear the crank.
I just did mine not long ago and that was the issuse I had was the pan catching the crank because the cross member wont not slide far enough forward.
I also installed a new oil pump while I had it tore down that far as they are not that much money anyway.
69GWC is offline   Reply With Quote
